Question about Cook's Essentials Home
Broken valve can I get a replacement?
Fix broken graywater valve and pipe 2002 r vision 5th wheel trail bay
find a caravan shop and they will probably have a range of valves that will fit. Most of the piping will be PVC piping that can be replaced and joined using a PVC glue available at the caravan shop or from a good hardware shop.
Feb 19, 2015 | Cars & Trucks
T30 2545 relief valve on manifold head
One of the valves is broken. need to replace valves.
Dec 18, 2013 | Ingersoll Air Tools & Compressors
I replaced the snap ring and retainer because they were both broke and still no luck with overdrive working
Overdrive would not engage at 35+ mph. Took trans pan off, removed filter, dropped valve body out. Found broken snap ring on overdrive servo. Removed and replaced snap ring. Opened valve body and found 1 of the broken pieces stuck in a valve. Replaced all valve body gaskets. Put valve body back in with 95 in/lbs torque. Put in new filter. Pan on with 120 in/lbs or 10 ft/lbs. Refill with trans fluid. Run through gears. Lower vehicle. Test drive.
Oct 30, 2011 | 2004 Ford F150
Does the timeing belt have to be on for the crank to turn the cam when instilling the timeing belt?
Are you replacing a broken timing belt? Or are you replacing a belt because it's due by miles? If the belt is broken, i strongly suggest inspecting for bent valves. Daewoo is notorious for bending all valves and breaking valve guides in the cylinder head when the timing belt breaks. The broken belt is also common.
Aug 05, 2011 | 2000 Daewoo Nubira
Broken Timing belt on peugeot 106 1100 cc will valves & pistons
i presume its a tu engine!? these are very good engines and have been known to survive a broken cam belt. i would try one on it before replacing any valves mate
if this helps let me know
cheers
big mike
Mar 12, 2010 | 1991 Peugeot 405
BOTTOM IGNITOR BROKEN,REPLACED STILL WONT FIRE
you need a volt meter to check this but if you can find you safty valve you can see if power is flowing through it by disconecting the ignitor and measuring the wire that comes to the ignitor and the other one that goes to the valve. if you have power you need to replace your saftey valve.you may allso ohm check the valve.if its open its bad
Mar 06, 2010 | Kenmore Ovens
1997 plymouth grand voyager v6 3.0L broken timing belt
I had the same thing happen, No, I was told this is not one of the engines that allows the piston to contact the valves. I replaced the timing belt 2 years ago and had no valve problems.
Sep 22, 2009 | 1997 Plymouth Grand Voyager
BENT OR BROKEN VALVE
If you are referring to an intake or exhaust valve, cylinder head must be removed (and likely replaced if valve is broken) Also if that's the case, pistons may be badly damaged and not even worth tearing down. If another valve (tire, egr etc, just remove & replace)
Apr 05, 2009 | 1999 Chrysler 300M
Home Logo
Top Cook's Essentials Home Experts
Jerry Kramer
Jerry Kramer
Tom Chichester
Ellen Tumey
Ellen Tumey
Are you a Cook's Essentials Home Expert? Answer questions, earn points and help others
