Question about Hozelock Garden
Cut out cascade 1500 trips fuse board after 70 seconds
2 Suggested Answers
  • 634 Answers
SOURCE: my pond pumps faulty
sounds like the pump has shorted out internally and needs to be replaced, try on different circute first to see if breaker is not faulty
Posted on Jul 17, 2009
My 70 amp battery fuse tripped so I put a 60 amp fuse in it tripped also all connections look good no bare wires ect..
a 60 amp is not rated high enough so that is why it tripped,it needs a 70 amp....if this was a house you could have started a fire
Mar 18, 2015 | Cars & Trucks
Ricoh aficio mp 2045 sc 542
Description Fusing temperature warm-up error
The fusing temperature does not reach the fusing standby temperature of 45C (113F) within 9 seconds [for the B003/B006 (35 cpm)]/14 seconds [for the B004/B007 (45 cpm)] after switching on the main power or closing the front cover, or 40 seconds after reaching 50C the fusing roller does not reach warm-up temperature. Causes • Fusing lamp defective • Poor fusing unit connector • Thermistor warped or broken • Thermostat has tripped • BICU defective • Power supply board defective
Jan 04, 2015 | Ricoh Office Equipment & Supplies
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
Sep 01, 2014 | Indesit Washing Machines
Double Horse 9053 Volitation Gyro cuts out
Most likely a fault with the PCB circuit board and needs replacing. Also check the motors and rotors are running freely as this could also cause the PCB to trip off.
Kind regards, julian.
rccontrolfreak.co.uk
Dec 18, 2013 | SYMA Toys industrial 9077 Double Horse...
Screen cascades slowly when opening programs or files
two possibles
needs more memory
but before that run this disk optimizer utility to make sure files are in best order
Jun 13, 2012 | Computers & Internet
Plugging the console into my house caused a breaker to trip. Resolving that my house does not generate enough power to play the console, anh attempt to plug it in at a friend's house only proved it no...
yes and yes. lots of places places fix it for about 70 euro. ps3s dont use that mush power. to definatly solve the problem run a cable from your fuse board and put the socket on its own 20 amp circuit breaker. this will definatly solve it.
Dec 11, 2009 | Sony Playstation 3 (PS3) Console
How to set up a Hozelock cascade 1500 pond pump
if there are no markings, check each opening for a vacuum with a small piece of paper, the one sucking in is the inlet, the other is the outlet
Jul 25, 2009 | Cascade 1400 Gph Pump
The dryer heats and shuts off in about 30 seconds repair guy has changed a thermo fuse? and i still have the problem i've checked my ducts no blockage it runs on air and delicate fine but on reg heat in...
its your timer that needs replacment. not the thermal fuse.
if the thermal fuse was ever tripped, it would not start at all. you would only hear the ticking of the timer.
if other cycles work its the timer not any of the sensors or fuses.
dryers are very basic, and are completely controlled by the timer (or control board for digital models)
Jun 16, 2009 | Dryers
My pond pumps faulty
May 24, 2009 | Garden
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
Garden Logo
Top Hozelock Garden Experts
richie46
Bill Boyd
Vernon Taylor
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
