Question about Emerson Quiet Kool 6GC53 Air Conditioner
How many btu's is the emerson quiet kool 6GC53 air conditioner?
How many btu's is 6GC53
SOURCE: Emerson Quiet Kool Drips Water into the house
depends on the unit. you will probably have to slide it out of its case and clean the outside part . there should be a hose that goes from the inside to the outside for the water to go out. this hose may be clogged, trapping the water inside. as i always say a picture of the unit always helps so i can identify it and tell you what to do to try and fix the problem. email the pics to eyg2181@yahoo.com
Posted on Aug 05, 2007
SolutionGuy
  • 331 Answers
SOURCE: Emerson Quiet Kool 6GC53 Air Conditioner
Chesapeake, given your symptoms you'll be looking at installing a new Selector Switch. But, before you go there... UNPLUG THE UNIT OR SHUT OFF THE BREAKER!!! Your selector switch does two things at a time, It energizes the fan motor (which it IS doing) and energizes the compressor at the same time. The voltage to your compressor goes from the wall into the selector, out of the selector, through the temp control then to the compressor. When the temp control is satisfied, it interrupts power to the compressor. The click you hear is the temp control being NOT satisfied and trying to send power to the comp. But if there is "no power" to send (i.e., the selector switch has failed)the compressor won't know to engage. Remove the front panel and filter. Remove the control box housing. Remove the knobs from the controls. You will now see the selector switch. Remove the 2 screws that fasten it (don't remove the wire yet!) and install the new switch. Then, one wire at a time, remove the wires from the old switch and install them on the new one. ***If you have an OHM meter, check the temp control before ordering a selector because this may be the problem and NOT the selector! To do this... remove the 2 wires from the temp control, set the control to "coldest". Then with your meter, test OHM's between the terminals. If you see "zero" OHM's, it's good. If you see no change in your meter, it's bad and THIS is the source of your problem. If you don't have a meter... you can test using this procedure... cut a 6" length of wire and strip the ends to about 3/8", twist the copper ends tightly. Remove both wires from the temp control, then insert one end of your jumper wire into one terminal and the other end into the other terminal. Make sure the "jumpered" wires are away from anything metal!!! And plug the unit back in. Now turn the unit on. If the unit fires up? It's the temp control, If not? it's the selector switch. Here's a link for parts...http://www.repairclinic.com/0080.asp
Posted on Aug 09, 2007
kstfas
  • 75 Answers
SOURCE: 1990's Emerson Quiet Kool window air conditioner
Hi, It opens a flap that allows fresh outside air to come in. The opening it screen covered on most units so no insects get in. To get the most cooling it is best to leave it closed. If you want fresher air, open it. Please rate my suggestion if it has helped. Thank you and, Have a good day. kstfas
Posted on Sep 07, 2007
tebot
  • 15 Answers
SOURCE: Emerson Quiet Kool 700 roof mount air conditioner
It should have a drain so that it runs down off the roof instead of into the motorhome. All a/c's have a drain somewhere and they all plug up occasionally. A/C techs always carry coat hangers.
Posted on Mar 30, 2009
  • 24 Answers
SOURCE: BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
Posted on May 27, 2009
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
I need to remove the blower motor from my Emerson Quiet Kool model 1350, how do I do this..
First open the control panel and remove all wires of your fan motor from the control switch and the capacitor. Remove also the compressor wires. Unscrew all panels and move the evaporator farther from the mounting base Pull-out the fan motor assembly with the panels. Unscrew the blower, fan blade, and them from the assembly. Unscrew the motor and now it is free.
Aug 31, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
I need a master control knob. I don't know the model number of the Emerson Quiet Kool air conditioner.
Without the Model Number, it's hard to know what knob fits your model. However, the link below, may provide some help. But, having the Model Number would be a bulls eye. Remove the front of the AC unit. There may be a manufacturer's data plate inside, which would provide the model number.
http://www.appliancefactoryparts.com/airconditioners/emerson/emerson-knobs.html
Hope this helps you.
Jul 13, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
I need a select knob for model #10mw42k-d part#a5 1121 22410-001 1121-900000-001 knob broke
If you need one quick I buy generic knobs from my local ACE hardware store they work fine and are cheap. good luck
Aug 10, 2010 | Emerson Quiet Kool 6GC53 Air Conditioner
Ac makes a grinding noise...does it have to be lubricated? my neigbor below complains that the noise keeps her up all night. need your help. thank you,
mcdevito75 here, Either the fan motor or compressor, I'm leaning toward the compressor, Hve your local a/c repair shop look at it, they come to the house, if compressor, expensive repair maybe better to replace a/c altogether
Jun 21, 2010 | Emerson Quiet Kool 6GC53 Air Conditioner
Emerson quiet kool model.eqk 1350 f serialo 20e 808320 wont heat, does it have an element? where is it located?
I looked up the model number parts
Their does not appear to be a heating element associated with this ac nor a reversing valve so I don't think it has a heat feature. You could mount it backwards and heat an area. That would look weird.
Apr 29, 2010 | Emerson Quiet Kool 6GC53 Air Conditioner
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
Have just bought an airtech elite have no manual...we not sure if we operating it right
Almost all Emerson product manuals are available on line in pdf format. It may take some time to locate them, but they are there....
Feb 03, 2009 | Emerson Quiet Kool 6GC53 Air Conditioner
Emerson Quiet Kool 6GC53 Air Conditioner Logo
29 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
