Question about Minolta EP4000/5000 CS/PRO Copier
Ep3000 how to clear a code co200 - Minolta EP4000/5000 CS/PRO Copier
  • Minolta Master
  • 6,161 Answers
Sir/Mam
Open close the front door. if it comes back the charge corona wire above the drum or the transfer & separation wires are the problem. The charge wire is above the drum have to remove the drum section to see it they are very thin gold plated wires that place a electrical charge on the drum prior to the image being placed on the drum.
The Transfer and separation wire are directly below the drum Transfer allows the image to be placed on the paper as it comes underneath the drum and above this very thin gold plated wire, The separation wire the second one prevents the paper from sticking to the drum. The xfer/sep assy. wires are located directly under the drum. then are very thin mite be broken. Grounding the High voltage. pull down and pull out the assy. to check it. There is cleaning handle try pushing it back and forth. If they are broke replace tem very carefully. Percission Roller may have them
If available
Posted on Dec 29, 2014
Minolta cf2001 photocopier, showing error co200.
try a hard reset.
by plugging off the unit from power for one night and then using it again.
Oct 02, 2008 | Minolta Office Equipment & Supplies
On display showing problem code 500
Sir,
To clear this code requires you to gain access to the System reset. Open front door locate a small panel with one screw to release it in side will find two small black buttons find service and let machine reset if the code persists then your fusers is gone, the EP3000 is a legacy equipment may find a problem in locating spare parts if the thermistor, thermosat or fuser lamp is shot. Ensure machine is on when you attempt above.
Sep 06, 2012 | Minolta Office Equipment & Supplies
Minolta cs pro EP3000 copier. The copy is too dark even on lightest.thanks
Clean the optical parts:mirrors,lens and the charge and transfer/sepaRATOR CORONAS.
May 13, 2010 | Office Equipment & Supplies
EP3000 error code c0500 will not clear
Sir,
Feb 02, 2010 | Konica Minolta DiALTA Di200 Copier
Minolta ep3000 service m1 ? and how to reset ? can you help
M1= main motor
1. Does the transport motor (M1) operate during power up?
NO, Ensure the connection of the connector (PJ21A) is secure.
2. Replace the transport motor.
YES, Check if there is excessive load on any of the rollers,gears,etc.
3. Replace PWB-A.
Jan 22, 2009 | Office Equipment & Supplies
Help
your heat lamp is not turning on, did you change it? generelly some copiers that old may have to disapate charge in the electronics after being worked on. if the copier did not initiate after rebuilding or doing work on the fuser, you may need to actually unplug it from the wall, like a reboot. the electronics are dated 8 to 10 years old. make sure, if it has a power relay or fuse, because of its age , they are good. generally older units will fire back up at off and on. if nothing works, let us kow.
Dec 07, 2007 | Konica Minolta DiALTA Di200 Copier
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
