Question about Mitsubishi WS-55819 55" Rear Projection Television
Mitsubishi non powerup problem
I have a ws55819 mitsubushi rptv that has a forever blinking power light issue. i can not establish a sequence (code)with it and will not power up and makes no sounds. i unpluged it to reset to no avail. it has suffered no surge to my knowledge and has been on the same protection equipment as the rest of my gear. any feedback as to coarse of action to heal this beast at home?
  • bsnody03 Jun 20, 2009
    model # stated incorectly. should have been ws 55859. i now have service manuaul and documented repair info, thanks.
  • 139 Answers
If it is a steady blink then it will be something with the microprocessor not resetting. That set does give fault codes by blinking in a pattern, like two blinks then a pause then three blinks.
It can be a little tricky to troubleshoot, I think that set has a micro, two eproms and another IC that they called a watchdog which has a lot to do with the micro and preventing it from locking up. It may also be a power supply problem not supplying proper power to the micro. I'd try a few more unplugs and maybe plug direct to outlet and bypass surge protector. If it won't reset you'll need someone familiar with that set to service it for you.
Posted on Jun 19, 2009
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Wd-62725 mitsubushi
Set if unplugged and plugged back will have the power light blink for about 70 seconds and then go out---then set can be powered up.
This is the set "booting up" and if green led fails to stop blinking a serious problem which is common in these is present.
Google the model number in this case with blinking green light, sometimes referred to as the "blinking light of death" in these sets
Mar 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
The power wet off and now the timer green light is flashing and it wont turn on model # ws 55511
Thats caused by the 7 capacitors on the DM power board. They discharge when the power is lost and then cannot recharge when power is restored and the indicator light will blink non stop indicating the DM has not completed the boot sequence. Replace the DM caps. The WS48511 - WS65511 DM repair kit is the correct repair kit for your model. You can get the repair kit from www.tvrepairworld.com
Jul 08, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Blinking light on the mitsubishi projection tv & not turning on
A non stop blinking light is indicatring a problem with the Boot sequence. I will need the model number of your set as some models have known issues with bad DM capacitors that cause that symptom.
Jun 15, 2011 | Mitsubishi Televison & Video
Model WS55819: Shut off by itself. Power ON with remote, Green light next to power button on TV flashes twice fir 10 cycles and shuts off. Unplugged TV for 30 minutes and for 4+ hours. Same results.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
you will have to count the blinks, then there is a short pause and then following a second set of blinks this tells what is wrong with set.
Mar 07, 2011 | Mitsubishi Televison & Video
Power went out, now the tv just blinks at me. I
Does the blinking continue non-stop forever? If it does, it is most likely the CAPS in the DM module. If you can solder or know someone who can, this is a fairly simple repair. Some sets have 4 CAPS, yours (WS-65711) should have 7 in the DM module that will need replacment. There are many step by step sets of instructions on how to do this repair. Google mits blinking green light of death. You will find loads of information and help.
Dec 19, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Screeching heard on powerup
The screech any chance there is a fan nearby that could do with a little lubrication?
May 17, 2007 | Zenith Z46Z83D 46" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
