Question about Konica Minolta bizhub Office Equipment & Supplies
How to calibrate touch screen on bizhub c352 - bizhub Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
1. Press the Accessibility key.
2. Touch [Touch Panel Adj.].
3. Using the tip of a pen or similar object, touch the four crosses (+) on the screen in
sequence.
• These crosses may be touched in any order; but be sure to touch the center of each
cross.
• Use care not to damage the screen surface with the tip of the pen.
Posted on Dec 30, 2015
  • 12 Answers
SOURCE: where do the staples go in a bizhub C352
Tha stamples go in a finiscer cover, you have to open front finiscer door and, on the left you can see the stample unit. Stample unit, in normal condiction, is positioned indoor, but you can move it by lcd dysplay funcion (stample chage) or in manual mode by rotation the green herness (stample movement).
Sorry for my bad english.
Bye.
Posted on May 15, 2009
  • 24 Answers
SOURCE: what fuse to use to reset the fusing unit on a bizhub c352
If you are in the UK you can buy the fuser fuse from RS components it is part number : 541-3221 http://uk.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=541-3221
Posted on Jun 25, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub c352 not printing black. I change the
The toner is not install properly. At the front end of the toner cartridge has an opening and a slide cover when you push the cartridge. underneath is the black developer unit which it has same opening and a cover some tines the Spring of those two opening cover might come of or tech intentional removing the spring so the opening stay open. but those two opening cover have to engage to open each other to open permitting the toner to drop to the developer unit. examine the the front end of the developer unit and toner cartridge slide covers.
Posted on Jul 09, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: can you reset fuser counter without replacing the
You can. You have to remove the fuser, and replace the counter reset fuse that is soldered into the wiring harness, then re-install the fuser. 10 minute job but not a one I would recommend unless you know the machine pretty well. Depending on your location and service options I would try to find a local independant repair person who can do this for you. I reset 20 to 30 of these fusers per year. Note you can also reset your transfer belt unit as well as your Imaging Units as well.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Jan 06, 2011
Testimonial: "thank you very much. I can tell, you're really an expert. your response was very helpful, i will contact a good technician right away to change fuse."
tinualbinale
  • 436 Answers
SOURCE: DRIVER KONIKA MINOLTA BIZHUB C352
You can select and download the driver from the following link.( http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=906&filetypeid=0 ).Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Posted on Jun 14, 2011
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
I have a proplem in konica minolta bizhub c352 how to sort the problem i have an error code 3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. ENSURE YOU WAIT THE 10 SECONDS
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 15, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub c352 error 3451
"Konica Minolta C352 - cyan and white pattern background on every print?!
What are you printing a Word document when this happens ?
suspect pattern may be in the software you are printing from.
Go to software help screen and look search for removing background pattern or removing watermark.
Apr 11, 2014 | Konica Minolta Bizhub C352 Digital Copier
Touch screen not responding
Shut it off for a few minutes and turn it back on to see if it works.
Nov 06, 2013 | Konica Minolta bizhub C352
I would like to teach me to scan the Bizhub C352, ie what are the steps to take to scan a document in BIZHUB C352. thank you Manuel Medina papelariapatrick@hotmail.com
Mack a scan folder on your computer & share it to network the you go on c352 and press scan key - direct input / scan to SMB / reference / work group open / your pc name open / scan folder ok -you are ready to scan any document any help you con- me 919899653281
Mar 19, 2013 | Konica Minolta Bizhub C352 Digital Copier
How to find server name for bizhub c352
The fiery network info can be found by pressing the small "i" in the bottom corner of your screen and selecting the config option. You can also access fiery settings by pressing "utility/counter" followed by "controller detail".
Mar 05, 2012 | Konica Minolta Office Equipment & Supplies
149 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
