Question about Kitchen Appliances - Others
Rational oven shows error 43 when running cleaning cycle??
5 Suggested Answers
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
  • 2926 Answers
SOURCE: Maytag Oven MEW5530BAW throws error F1 after
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Importatnt. few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Posted on Feb 07, 2010
Testimonial: "I tried this and it did get the F1 error again leading me to believe it is the ERC. This was great advice Thank you. "
BarrettDenCo
  • 1772 Answers
SOURCE: Used the self cleaning cycle 24 hrs. ago, but the
Sorry to read about your problem, I hope this helps you out.
you may have done a panel lock, so try the first solution.
To Lock/Unlock Control: Before locking, make sure the ovens, Timer and Timed Cooking are off. Press and hold START/ENTER until a single tone sounds and "Loc," a picture of a lock and "START?" will appear on the oven display, about 5 seconds. Repeat to unlock and remove "Loc" from display.
To Stop Self-Clean any time:
Press UPPER OFF, LOWER OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Posted on Dec 25, 2010
k14cks
  • 20 Answers
SOURCE: Hi I have a combi rational oven shows error 10 . What should I do? The oven didn't do cleaning and has error then service 10 appeared. Thanks
Service 10 is usually caused by a blocked or defective steam generator emptying pump.
Replace the pump or clear out any scale buildup.
Once the problem is corrected you must do an automatic drain to clear the error.
Posted on Feb 28, 2017
How do get rid of Error 25 on a rational combi oven ?
Just run the Cleanjet cycle again. If the problem is fixed, the error will go away.
service 25: no water pumping during Cleanjet cycle
Nov 09, 2017 | Combi Ovens
I have rational CM61 E ,display showing error E12, if know this anyone pl. share this
Hi, error 12 is displayed when the oven pcb is too hot, check that the air filter is clear and the cooling fan is running. Also it could just be the software, if it is an older oven and has the original software then it may just need upgrading by someone who knows what he/she is doing.
Jan 05, 2014 | Combi Ovens
I have one rational oven showing error 34
34 what there should be a no after 34 ie like 34-6,34-8 etc
Mar 22, 2012 | Ovens
Error code E3 - F3 on Whirlpool oven, RBS275PDB12
Error E3-F3 says that the Oven temperature is too high(Clean mode).You might have to replace the Oven Temperature Sensor(RTD).
Apr 19, 2009 | Ovens
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
