Question about Home
I have a grundig kitchen weighing scale. The display mode shows but it does not function.
Job number: 6159 Product number 1805302
ButtFuzz
  • 463 Answers
SOURCE: My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Posted on Mar 16, 2009
UpfrontAudio
  • 47 Answers
SOURCE: safe mode on Grundig 200 car radio, do not know where to find serial number.
Grundig 200 car radio can decode in the next way:
First step: Switch off the radio and the ignition as well.
Second step: Push the AS button and keep it pushed, at the same time turn on the ignition.
After this you will hear a beep sound. Now you can release the AS button.
Now you can enter the code in the next way: The first number can be set with the button ''1'', the second number of your code can be set with button ''2'' and so on. By pushing the ''1'',''2'',3'',''4'' buttons the value indicated in the screen will be increased by one. So if the first number of your code is 5 then you have to push the button ''1'' 5 times.
if this doesnt work then it will be cheaper to buy a new car radio contact me and let me no how you get on :)
Oh and the serial number is either engraved on the side of the unit or an actual sticker which is in the format you describe. You'll need to remove the unit from the dashboard to be able to get access to this.
Posted on Apr 20, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
SOURCE: What does the Bone Mass number mean on my digital scale?
I found this from another posting. Hope it helps.
FEMALES: age 20-29 normal= 6.2-7%
FEMALES: age 30-39 normal= 6-6.8%
FEMALES: age 40-49 normal= 5.6-6.4%
FEMALES: age 50-59 normal= 5.2-6%
FEMALES: age 60-69 normal= 4.9-5.7%
sorry no listings over age 69
My only thing now, is what it means if I am below the range.
Posted on Jan 13, 2010
fb62685
  • 4 Answers
SOURCE: My Terallion electronic kitchen scale shows an out2 error
I had already solved this after a lot of playing and research, put I thought I;d post it on here for others as the answer was different for other scales listed here. What I did was press the 'Button 1' and 'Button 2' together for 5 seconds. This powered it up and then the display showed 'Cal' with a number on the screen. I pressed 'Button 1' again and it said 'Zero' and then displayed the numbers '0000'. Then I added 1kg of weight and it said 'Cal1'. Then I added 3kg of weight. It said 'Cal2'. Then I added 5kg of weight. It said 'Cal3', then 'Pass'. It then returned to normal mode and now started weighing correctly. I calibrated the weights (Flour and Sugar packs) on another set of scales first, but they were only a few grammes wrong so would be close enough anyway. I hope that helps!
Posted on Dec 04, 2012
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
Where can I get a operating manual for silvercrest digital kitchen scales num: Z30170. in english
http://www.lidl-service.com/cps/rde/xchg/SID-EE4A0FEC-2E826FB3/lsp/hs.xsl/product.html?id=8346817&title=Digital+Kitchen+Scale&count=1
Aug 04, 2011 | Microwave Ovens
I just received product JB5413. Batteries were just purchased today. The remote is working fine, but it will not weigh. The instruction manual is minimal. I need help getting this to work.
If it's any consolation my Jobar/Ideaworks JB5413 scale has the a similar problem: will not weigh, yet the remote control functions okay. About one attempt out of ten will cause a weight display, though. Can't figure out why scale works occasionally, vs. never works. Batteries are new, and the battery compartments are free of corrosion.
Jan 15, 2011 | Jobar International Ideaworks Remote Read...
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
May 14, 2010 | Salter 2001 electronic kitchen scale
I have a Hobart Digital Scale model 7930 that will cycle through its turn on mode but shows a blank screen from the scale any suggestions?
have you tried changing the batteries? sometimes if the batteries are weak it will have enough power to power up but not enough to power the display in weigh mode
Mar 11, 2010 | Health & Beauty
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
My salter 1004SSDR kitchen scale won't show any real weight - just stuck on '5000' which is the max weight in grams, won't switch off, crazy
Your salter scale has a 15 year warranty. I would call the customer service number 1-866-843-3905 and ask them why it won't zero to weigh anything. They may replace your product.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Home Logo
129 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
