Question about Samsung SC-D353 Mini DV Digital Camcorder
  • 2 more comments
  • Anonymous Nov 02, 2007
    tenho uma sansung sc 353 mini DV mas o programa q o acompanha é muito ultrapassado e preciso de um mais atual.. é o Ulead videoStudio 11
  • Anonymous Dec 03, 2007
  • shawn23 Feb 08, 2008
    my ribbon cracked and my lcd is only white and thats just when its in the right position. The monitor is usually pitch black. I took it apart and noticed the crack but i need a link to a site where i can order a new ribbon
  • debsyota00 May 11, 2010
    What is the exact link for this spares dept? I did a google search and did not find it.
Try samsung spares dept £12.50 +postage
Posted on Nov 07, 2007
Helo. How much to replace defective ribbon cable for lcd screen on sony dcr-sx41?
The part usually costs around $35 and the labor varies from shop to shop. This will require disassembling the camera and LCD unit to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on
Sep 05, 2011 | Sony DCR-SX41 Camcorder
Dcr-hc32e no picture on side screen, any solutions ?
There is flexible ribbon wired between lcd board and camcorder board, it seems broken so no image on side lcd screen.
Replace flexible ribbon wire by local camera repair shop because camcorder will take apart for that.
Nov 19, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Replace LCD monitor on Sony DSLR a350
The You-Tube video is useful.
Care must be taken when removing the ribbon-cable connector from its mating half on the camera ribbon-cable.
The black strip on the mating connector has to be flipped back, away from the display ribbon, to release the display ribbon.
Then after locating the new ribbon fully home, the same black strip has to be flipped forward in the direction of the display ribbon and pressed down to clamp this connector in place. All this is shown, but quickly in the video.
Do not touch the bare surface of the new display or the inside surface of the removed display protective surface which has an optical coating which easly shows fingerprints.
Aug 23, 2009 | Sony Alpha DSLR-A350K Digital Camera
I am trying to repair or buy a P-TWO AWM 20696 E221612 cable
you will have to order the required cable here
check out this link
if this link do not help then check out for this another link
u will have to contact them if the cable is not mentioned and they will get it for u and provide you.also u can send mail if the contact numbers r not working
Tel:086-571-87804996 dot2.jpg Fax:086-571-87804033 dot2.jpg Email: dot2.jpg Email:
Dec 16, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Replacing the lcd screen on casio exilim ex-z77
the LCD will have a ribbon cable going around to the front and it will also have two small wires red and black for the back light. those have to be desoldiered and the ribbon cable unplugged and gently removed. I repair these camera all the time and this unit is a pain. If you do not fill comfortable replacing the parts you can go to if you need further assistance.
Sep 30, 2008 | Casio Exilim EXZ75 Digital Camera
Dark screen- No images- some shadows horizontally
If you get a blank LCD, dimly lightened by a whitish back light, then the LCD display eis either faulty, badly connected, or the ribbon connector to LCD is defective.
The camera must be taken apart, ribbon cable tested, and eventually replaced and adjusted.
If all contacts on ribbon cable return continuity (cable is fine), then LCD is faulty, and must be replaced.
Althought the job is not too difficult, an user without experience may damage the camera in attempting this repair.
My first suggestion is always taking the unit to a camera shop.
Aug 23, 2008 | JVC GR-D90U Camcorder
Lcd screen
Well, you're not going to fix this without opening up the camera.
The LCD screen should have to wires going to it. One is for the light that illuminates the LCD. That one is obviously working. The other is for the LCD itself - it sounds like that isn't. Either the LCD needs replaced, or that cable is loose or damaged. I'd suggest opening up the camera, finding that cable (it will likely be a thinner cable than the other), and checking for loose connections, or an obvious break or sharp bend in the cable.
Unfortunately, even if you find the cable is damaged, I'm not sure you can get it replaced. If you're not confident you can take this apart and put it back together properly, I'd suggest either taking it to a repair shop, or just using it as is. I'd hate to see you damage it further. If you are confident, however, check that cable. If it's good, contact Samsung about a replacement LCD.
Dec 20, 2007 | Samsung Digimax i5 Digital Camera
Need to replace LCD screen
SOLUTION FOR V803 ONLY - DAMAGED SCREEN It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard1.gif. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock1.gif the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Nov 17, 2007 | Kodak EasyShare Z700 Digital Camera
Screen i broken
Yes it can be fixed.  Depending on where you live will depend on what you do next.  you can go to any phot repair shop and they will either have the part and can fix it there or they will need to send it out.
Either way, it'll be cheaper than buying a new camera.
Oct 27, 2007 | Kodak EasyShare C315 Digital Camera
SD400 broken screen
found this guide on the net once, try it out and let us know what you think: " WARNING: this repair voids your warranty and may damage your camera. Perform at your own risk. The publisher of this site is not responsible for any damage you cause. This replacement is of medium difficulty. If you have ever ?built? a computer from parts, you are probably capable of it. If you are patient, orderly, and meticulous, you can probably do it. But you do risk breaking your camera even further, so don?t do it if you won?t accept that risk! Be carefully that you are grounded and thus do not harm the camera via static discharge. Google the terms ?grounding? and ?static discharge? if you need more info. I only performed this operation on a Canon SD300 / Ixus 40, but readers have reported that it is the same on the SD200 / Ixus 30 and on the SD400 / Ixus 50. Read all of the instructions before proceeding. Within each step, I don?t necessarily use exact chronological order. Tools: a small Phillips head screwdriver and a smaller flathead screwdriver (used for prying). Step 1. Ascertain what is broken. Symptom: your screen still glows with light, but shows crazy colors or a visible crack surrounded by crazy colors. Problem: your LCD screen is broken but your backlight still works. You need only purchase a new LCD screen. Symptom: your LCD does not glow. Problem: your backlight is probably broken. This didn?t happen to me, so I don?t give any further advice about this problem on this page. However, the information on this page will take you about 60% of the way to replacing the backlight as well, so it may be useful. Step 2. Order a replacement screen. UK: H. Lehmann's Ltd: +44 (0)1782 413 611 at a cost of 33 GBP (including shipping) US: Canon? +1 732 521 7230 / +1 800-828-4040 at a cost of around 66$ (including shipping) The part number for the SD-300 / Ixus 40 LCD screen (without backlight) is: ck9-1103 The part number is the same in the US & UK. I do not know whether the SD-200 / Ixus 30 LCD / SD-400 / Ixus 50 LCD part number is the same.. Step 3. Open the camera - Remove 6 screws in total: 2 from the left side, 2 from the right side, and 2 from the bottom. - Gently pry open the case - The plate covering the ?grommet? to which you attach the strap will fall off. So will the round grommet. Don?t worry about it. Step 4. Remove the screen & backlight assembly from the back of the camera - Remove the screw from the upper right corner of the backlight/LCD package. Note: this screw is of different size to those you have already removed. Keep it separate. - Be careful of the tongue extending from the bottom right corner of the backlight/LCD package. It?s very tiny and easy to miss. You want to be sure to slide it out, because it?s easy to just break the plastic into which the tongue slides. (I did. Not a huge crisis, but I wish I hadn?t!) - There is a tab on the left side of the backlight/LCD package. Pull it back slightly so you can lift the backlight/LCD package. (I used the flathead screwdriver to pry it off.) - You should now be able to lift up the backlight/LCD package. It will still be connected to the camera body via two ribbon cables. Step 5. Separate the LCD from the backlight - There are a number of fiddly plastic/metal tabs holding the two together. Just gently pry and poke until you have separated them. It?s a bit time consuming, but I can?t really give better instructions than these. - You should be left with the LCD totally separate from the backlight, but still connected to the camera via a ribbon cable. - The backlight should also remain connected to the camera via a ribbon cable. Step 6. Undo the LCD ribbon cable - The LCD ribbon cable extends under the bottom of the camera (actually passing under the tripod screw hole, which cannot be removed). It re-appears in the front of the camera and is connected to a socket. The socket is rather like a DIMM socket on a computer. It has a flat, black, clasp which is folded down to hold the ribbon cable in the socket. - Examine carefully the way the ribbon cable is attached to the socket. Note that it is pushed in entirely, so that the wider part of the cable (with two holes at either side of it) is flush against the socket. - GENTLY lift the clasp (I used the flathead screwdriver). It should swivel up and the ribbon cable should fall out. DO NOT YET PULL THE RIBBON OUT OF THE CAMERA. Step 7. Totally remove the LCD - Tape a long, narrow strip of paper to the end of the ribbon cable. This paper is to help you thread the ribbon cable of the new LCD back through the inside of the camera. - Note how the ribbon cable is threaded under the tripod mount to the front of the camera. Wiggle it around a bit, get a feel for it. Sliding the new one back through is a bit tough, so experiment with how this one fits and where it goes. - Gently pull the ribbon cable out from under the tripod mount, leaving the broken LCD screen now completely detached from the camera. Make sure to leave the paper threaded through the camera so that you can tape it to the new LCD?s ribbon cable and pull that one back through. - If you messed up with the paper, don?t worry. You can still push the new ribbon cable through: it just takes some wriggling and some time! Finishing. - You have now got to go through the process in reverse, installing the new LCD screen. - Threading the LCD ribbon cable back under the tripod mounting screw is tough. Just keep sliding it back and forth and exert pressure to push it through. It will go through, eventually. - As you connect the LCD ribbon cable, read the ?white screen? problem below, so that you do not suffer from it! FAQ 1. My screen just shows white or gray. (E.g. white screen, white display). What did I do wrong? A. The ribbon cable that connects the LCD to the circuit board was not inserted deeply enough. The end of the ribbon cable has a narrow portion, then a very small much wider portion with two holes at either end, then it narrows again. The very tip should be inserted into the "socket" deeply enough that the wider portion is pressed right up against the "socket." Physically, it cannot be inserted more deeply. It may help you to use two wooden or plastic toothpicks, one in each of the small holes at the end of the cable, to push the cable into the socket." If you feel like supporting the author of this thread, go to his website through this link: Good luck
May 18, 2006 | Canon PowerShot SD400 / IXUS 50 Digital...
Samsung SC-D353 Mini DV Digital Camcorder Logo
255 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
