Question about Beverage-Air MT45 Beverage Cooler Commercial
Beverage -air mt72 wiring diagram - Beverage-Air MT45 Beverage Cooler Commercial
4 Suggested Answers
refritech08
  • 149 Answers
SOURCE: Beverage-Air MT72
Bi-pin Fluorescent Lamp Installation /Verification Prior to applying power to the unit, verify that all lamps are properly installed and fully engaged in the lamp holders.
Proper lamp engagement is achieved by rotating the lamp 90° from its insertion position until it "snaps" or "clicks" into place.
Visual verification can be made on units without safety shields by using the identification mark on the end of the bulb. Properly installed bulbs will have the mark centered between the "halves" of the lamp holder.
On units with shields, the identification mark cannot be seen. Physically verify that the lamp has been rotated and locked into place.
Caution: Improperly installed lamps may cause damage to the lighting circuit. Beverage-Air shall have no liability whatsoever for equipment or component failures or other damages or losses which arise as a result of improper installation.
Posted on Apr 23, 2008
  • 1250 Answers
SOURCE: I've got a beverage air MT72 that heats up when we
many things to look at. The compressor could have lost it's ability to pump properly due to worn valves. You could have the wrong freon or the wrong amount. The condenser could be clogged up. The expansion device could be malfunctioning. The evaporator fans may not be running. Lots of things to check so you can start to narrow down the issue.
Let me know if I can be of any further help.
Posted on Jan 30, 2011
aquatom
  • 108 Answers
SOURCE: How do change out the door gasket (pull open) On a
Pretty sure u just pry it out and the new one you push back on its been some time since I've done one but call the number that's listed on the name tag inside the unit on the left top wall or right side wall they may be able to tell you that.
Posted on Sep 27, 2011
How do change out the door gasket (pull open) On a Beverage Air mod# MT72
Sep 27, 2011 | Beverage-Air MT72 Commercial Refrigerator
Door hinges keep sicking, what do I do
The springs are shot you need new ones and not an easy job I would call a local refrigeration company to take care of this problem.
I need a wiring diagram for a Beverage Air MT10, where can I find it?
moz-screenshot-1.pngmoz-screenshot-2.pngI followed the brown wire back to the common terminal on the condenser fan switch.
Jan 25, 2011 | Carrier Beverage-Air MT10-1 Commercial...
I've got a beverage air MT72 that heats up when we turn it on. We had a tech put in new refrigerant, which brought the temperature down from 90+ degrees down to around 60 degrees, but clearly refrigerant...
Dec 30, 2010 | Beverage-Air MT72 Commercial Refrigerator
Need to see if evap fans r working
http://www.beverage-air.com/uploadedFiles/docs/CFG_CRG_KF_Series809-046A.pdf
this site has your manual and the manual has wiring diagram.
also has some common trouble shooting questions and answers.
Jul 06, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
Compressor does not kick on, low side reading just under 80 psi. compressor problem?
could be. Check out the start components first. They are cheaper and easier than a compressor replacement.
http://www.beverage-air.com/images/barEquipment/manuals/BB%20manual.pdf
try this site. It has your equipment manual and wiring diagram.
Hope this helps. Let me know if I can be of further service.
Jan 29, 2010 | Beverage-Air Freezer GF48L
Beverage-Air MT72
Apr 23, 2008 | Beverage-Air MT27 Beverage Cooler...
Beverage-Air MT45 Beverage Cooler Commercial Logo
102 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
