Black and white lines skip and print badly on canon i860 printer
About 4 to 5 lines of type on a page looks fuzzy, and light printing
  • electronacs
    electronacs May 11, 2010
    what make and model printer
  • Chris Corbett
    Chris Corbett May 11, 2010
    laser or inkjet?
SOURCE: Canon i860 "printer offline" but light is blinking
Move mouse pointer on to your printer icon in the Printer folder. Does a right click and click on the sixth line of the menu (“Use printer on line”). Then it will change as “Use printer offline”. Make sure the printer is set as default printer.
Posted on Mar 21, 2008
Gletkin
  • 49 Answers
SOURCE: Large black ink tank is not being used by the printer.
The little cartridges are pigment for photo printing. The Large black cart is ink for plain paper (usually text) printing. If you select a photo paper in the print setup menu, you will use very little of the ink.
To check the function of the large cart print out a test sheet from the printer maintenance menu. You may need to run a head cleaning to get all the nozzles to work.
Posted on May 31, 2009
CompuGuy44
  • 432 Answers
SOURCE: printing black line when coping
You may need to replace the toner cartridge or the fuser assembly.
If you open the toner cartridge door and see a black line on the roller, you will need to replace the cartridge.
Posted on Aug 07, 2009
CompuGuy44
  • 432 Answers
SOURCE: Printing black line down middle of page when coping
The fuser is located in the back of the printer. I think it's held in by to screws. It's about hte same size as the toner cartridge. Please visit these websites.
This is the fuser kit.
http://store.printerprinciple.com/products/rm1-3044
The service repair manual.
http://www.scribd.com/doc/15253671/HP-Laserjet-3055-Repair-Manual
Fuser Replacement is on page 170.
Posted on Aug 08, 2009
pineworks
  • 4041 Answers
SOURCE: Printer willl print color but does not print black and white
Hi There You can try/
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Ink spots on back of printed page from Canon i860. What to do?
Type in your search engine How to get rid of ink spots on back of printed page from Canon i860 printer.
It will take you to How to download a manual that will help you fix this issue. PDF.
Jun 18, 2017 | Canon i860 InkJet Photo Printer
3e black cartridge not printing. Canon i860
Did you try another cartridge?
What can happen sometimes is that the print head can get blocked.
You can clean that by removing the print head from the printer. Do not touch the foil on the head or the print nozzles.
Boil some water, pour 1/4 of an inch (6mm) of water into a saucer, place the print nozzles in the water for a minute or so.
Take the print head out of the water and touch it on a paper towel to get the water off.
Reassemble the printer and see what happens...
Feb 20, 2010 | Canon Office Equipment & Supplies
May 11, 2009 | Canon i860 InkJet Photo Printer
After deep cleaning the print heads, it will only print one page
This sounds like the print head alignment is not stabilized and may indicate you need a new print head ($$$). Try looking in the Service Manual.
A copy of the Canon i860 Service Manual is downloadable at:
http://rapidshare.com/files/179582794/Canon_i860__i865_SM_-_printer1.blogspot.com.rar
The password to open the compressed PDF file is: printer1.blogspot.com
Jan 24, 2009 | Canon i860 InkJet Photo Printer
Printing in black "fuzzy"
have you replaced the ink art with a new one?
if you have time to replace the print head.
Dec 13, 2007 | Canon i860 InkJet Photo Printer
232 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
