Question about L. R. Nelson Garden
What size is the o ring on Nelson brass quick disconnect hose coupler
2 Suggested Answers
silawrence
  • 906 Answers
SOURCE: How do I install grohe kitchen faucet hose 46092000 from a 1992 faucet? I do not see a yellow quick coupler.
look at the ends you need to connect then go to a plumbing supply store and get the adapter.
Posted on Dec 19, 2014
Dec 19, 2014 | Grohe Home
My 20 gallon campbell hausfeld wont hold air.what could be the problem
Joe:
There is an air leak somewhere in either the tank connections or the hose connections. Look at the tank and find the tube that runs from the top of the compressor to the tank (usually a brass line). grab a spray bottle and fill it with a soapy solution (dish washing soap and water is fine). Disconnect the rubber air hose from the tank (at the quick disconnect) and start the compressor. Spray the dishwashing solution on the brass line end fittings at the compressor head and the tank connection, and the quick disconnect fitting and where the quick disconnect connects to the air tank. If you see bubbles being blown, that is where your leak is. Also connect the hose to the tank and check your hose for leaks with the soapy solution. Once you find where the leak is, you can tighten the fitting or replace the faulty gasket or hose.
May 25, 2014 | Air Tools & Compressors
Gas tank reserve valve
Recently, my quick disconnect started to leak...leak pretty profusely actually. Anyway, the Harley dealership tried to sell me an entire new quick disconnect. I insisted that there had to be an o-ring inside the disconnect, but the parts guy swore that there was not. After refusing to spend $58 on a new disconnect, I drained the fuel from the tank, removed the disconnect, and removed the cracked o-ring (the one that the parts guy said did not exist). A quick trip to the local parts store and I found the o-ring for under $1.
Just be sure to ask for one that is fuel resistant.
if I remember correctly, it's the same size o-ring as the oil drainplugs...a #41 I think.
$6.99 for the HELP o-ring kit at your local Advance Auto Parts has the o-ring you need...in fuel grade too.
Dec 10, 2013 | 2011 Harley Davidson FXDB Street Bob
1st time ever using a compressor. Need to disconnect the yellow hose from machine to move. I've pushed down on the bronze ring with texture, and then it's loose but not out. Don't want to...
It sounds like you are trying to disconnect a quick-connect fitting. Don't loosen the hex. No tools required. Just pull back a bit harder on the outer brass ring then pull out the male end of the fitting. You might have to push it, then pull it. A word of caution- if the male end is on a hose that has air pressure in it, it's going to very rapidly escape from the hose. If you aren't prepared for that it will startle you and you could hurt yourself. Just hold on to it securely and don't put your face too close. Good luck, Al K
Jun 21, 2011 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
Do i have to drop gas tank to change fuel pump on 99 grand am gt?
Yes. It's not a terribly difficult job though. First back the car onto some ramps and set the parking brake firmly. Disconnect the electrical connector for the fuel pump / fuel level sending unit. You will need to loosen the hose clamps around the fuel filler neck hose and the vent hose and remove the rubber hoses at one (either) end. There will be some 'quick disconnect' fuel lines. To disconnect these, you need to squeeze the two white plastic inside pieces together and pull them apart (it will be very obvious when you see them). Put a hydraulic floor jack under the gas tank with a piece of wood on top of it to distribute the weight of the tank over a larger area. Then you can unscrew the two straps that hold the fuel tank up and gently and slowly lower it down. Once it is down, there is a lock ring on the top of the tank that holds the fuel pump / fuel level sending unit assembly in the tank. Use a brass punch to loosen the lock ring to avoid sparks. Make sure to replace the fuel strainer and any O rings when you do the pump. Installation is (as always) the reverse of removal. Also, remember to drain any remaining fuel from the tank while you have it removed. This will make installation a lot easier.
Dec 07, 2010 | 1999 Pontiac Grand Am GT
How do i chage the fuel injector for a geo metro 1997 LSI?
REMOVAL & INSTALLATION Fig. 1: Removing injectors from fuel rail 84245032.gif
Fig. 2: Make sure injectors rotate freely in cylinder head 84245033.gif
  1. Relieve fuel system pressure and disconnect the negative battery cable.
  2. Remove intake air hose between throttle body and intercooler.
  3. Remove accelerator cable.
  4. Unclamp PCV and fuel return hoses from deliver pipe.
  5. Unclamp injector wiring harness.
  6. Disconnect injector coupler.
  7. Remove cold start injector pipe from delivery pipe.
  8. Remove vacuum hose from pressure regulator.
  9. Remove fuel feed hose from delivery pipe.
  10. Remove pressure regulator from delivery pipe.
  11. Remove delivery pipe with injectors.
  12. Remove injectors from delivery pipe. To install:
  13. Replace injector O-rings and lubricate with fuel. NOTE: Make sure injectors rotate smoothly. If not, probable cause is incorrect installation of O-ring.
  14. Check if insulator is scored or damaged. If it is, replace with new one.
  15. Connect delivery pipe with injectors.
  16. Install pressure regulator to delivery pipe using a new O-ring.
  17. Install fuel feed hose to delivery pipe.
  18. Install vacuum and fuel return hoses to pressure regulator and clamp securely.
  19. Install cold start injector pipe to delivery pipe using new gaskets.
  20. Install injector coupler. Clamp injector wiring harness.
  21. Install PCV hose to cylinder head.
  22. Install throttle position sensor coupler.
  23. Install accelerator cable and adjust free-play.
  24. Install intake air hose to throttle body and intercooler.
  25. Connect the negative battery cable.
  26. Start engine and check for leaks.
Jul 03, 2010 | 1997 Geo Metro
Leaking at point of connection between tip and wand
There is a rubber o ring in a groove towards bottom of the snap in connector.This seals around the tip as you insert it. It will never seal without it. The ball bearings you mention are only to hold the tip in place. The sealing goes on down in the coupler
Jul 02, 2010 | Briggs & Stratton Briggs Stratton ORing...
How do you remove the gas tank from a 2006 Chevy Trailblazer?
remove battery cables. jack car up adn place on jack stands so the rear whells are off the ground. remove real drive shaft. on the bottom of the tankmaybe a skid plate. unbolt it. on the side of the tank buy the driveshaft tunnel is a metal sheild. it is held on by pop stars remove stars and sheil. at the back of the tank is the vent and filler hose. remove those. place a floor jack under the tank. unbolt the 2 straps. remove the 2 straps. lower the tank 4-6 inches. you have to unhook the purge line from the tank. it is a squeeze fitting. lower the tank 4-6 inches more. tremove the electrical connector. you will need quick disconnect tools. remove the 3 feul lines. GAS will leak out. lower the tank to the ground and slide out from under truck. remove any debris from the tank. you heed a aluminum flat drive bar and brass mallet. brass and aluminum will not spark. there is a metal ring that compresses the gasket. there is a plastic tang open.have helper hold it open. you need to move the outside metal ring counterclockwise till the ring is released. hit the metal flat edges of the ring. alternating on them until the ring unseats. pull the pump up on an angle replace pupm. good luck
Dec 31, 2009 | 2006 Chevrolet Trailblazer
I have a power steering fluid leak. It is the coupling on the hose. How do I remove the hose? Coupling is something I've not seen before.
dear friend:the coupling your referring to is a quick coupler and has two buttons on the side that needs to be pressed together,this coupler has a o ring on the inside that can be replaced,
Aug 30, 2009 | 2001 Hyundai Santa Fe
Garden Logo
81 people viewed this question
Top L. R. Nelson Garden Experts
Dennis Key
Dennis Key
john h
Are you a L. R. Nelson Garden Expert? Answer questions, earn points and help others
