Question about Dell Dimension 3100 PC Desktop
My sound is not working but ihave sound cards and
My sound is not working but i have sound card and the mixer it says the audio application is failed, you have to have a audio device.
  • 34 Answers
Sounds like you have to go back and add the driver back in. Go to dell/support and then click on drivers. They have several diffrent type of drivers on there so you will have to pick them out one by one unless you know which is right for you. If you know about computers you can open the cpu where the motherboard is located and look for yourself to see what video card is attached to it. Hope this works for you.
Posted on Jun 26, 2009
  • 97 Answers
Probably a driver issue...check in the device manager and update the drivers for your audio devices.
Posted on Jun 19, 2009
I can't get the sound to work on my laptop, it is not muted and says it is on. Now what
If you are using Windows, you should check the "device manager", and verify that there are not any red x's or yellow !'s marked on any of the devices (specifically sound card). For Windows 7 or 8, I would also verify that the mixer (audio icon in bottom right corner of monitor) is not muted, also click on the word mixer, and verify that none of the individual applications are muted. You will also want to check that the sound is turned up on both your laptop and windows audio mixer (same icon in bottom right) .... usually these two should coincide with eachother, but that is not always the case. Also verify that the sound does not work for other sources (check web sites, windows media player etc... ) so that you can make sure this is not an issue with the specific application or a possible codec issue.
Sep 29, 2013 | Toshiba Satellite P105-S6177 Notebook
Headphone jack does not work
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Jan 21, 2013 | Acer Aspire Computers & Internet
The sound displayed "application failed
make sure that the sound card is securely seated with no dust in the socket then uninstall it restart your computer and reinstall the sound card and its drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
hope this helps
Apr 04, 2011 | E-Mu 0404 Sound Card
I have a Tascam TM-D1000 digital mixer that has a TDIF output and want to connect this to my computer. Do I need a PCI 822 card or is there another option to connect?
I have a TMD1000 connected to my computer via the RCA ( Red & White) outputs on the mixer to an M-Audio 2496 Sound card in the computer.
also via the Digital out on the mixer to Digital in connector on the card.
I then edit recordings on the computer with Cubase pro.
Nov 28, 2010 | Tascam PCI822 Digital Audio DTRS Interface...
Ihave problem in after install sound driver the mic is not working
Please restart the computer and check
click on start> go to control panel >click on sound and audio devices > uncheck the mute > click on voice tab> click on volume tab under voice recording check the mute option and uncheck the mute.
Still it is not working go to this site - http://www.kellys-korner-xp.com/xp_tweaks.htm
using internet explorer and run the tweak
Good Luck..
Sep 30, 2010 | Compaq Presario 700 470024-192 Notebook
SPI crashes and external audio dock is not working
take it to a computer shop its only £7.50
Feb 18, 2010 | E-Mu 1820M Sound Card
My toshiba laptop will not for some reason play sound. i have checked to see its not muted but it still doesnt work. any help?
Go to control panel > sounds and audio devices and have a look in there or click on the advanced button for the audio mixer. in the mixer, go to options > properties and select all the devices, close that and then turn up the volume on the mixer.
Dec 01, 2009 | Computers & Internet
Audio problem
You either have the wrong driver installed or a conflicting driver is present. Go to control panel->system->device manager-> look for the yellow exclamation point, double click on it and follow those instructions. If that does not work. Right click on the device, REMOVE, then reboot and let it refind it.
Jul 11, 2009 | Compaq Audio card Sound Card
Dell Dimension 3100 PC Desktop Logo
88 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
