Question about Health & Beauty
What is the joystick flash code meaning - Health & Beauty
  • 175 Answers
It flashes a given number of times to help diagnose a problem with the mobility device. It can mean anything from a low battery to a blown controller. Each chair comes with an owners manual that shows what the flash codes mean, or they can find the codes on the manufacturer's websites.
Posted on May 08, 2014
Hi, I have a S646 SE my joystick started flashing yesterday every 5 sec it flashes the w/c icon 3 times and the battery indicator flashes 3 red 4 orange & 1 green. What does this mean?
Most of the time a flash code of 8 means the controller has a fault. but sometimes there maybe a damaged cable connecting the joystick to the controller.Sorry for the bad news.
Strege Mobility
Oct 10, 2017 | Electric Mobility Power Electric Scooter...
My flash code is SEVEN PAUSE SEVEN which indicates JOYSTICK FAULT.
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
www.pridemobility.com/download.php?...Jazzy_600-600...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Jan 18, 2016 | Pride Jazzy 600 JAZZY 600
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
What does 7 yellow flashing wrenches mean?
With most wheelchair electronics a 7 flash means the joystick is bad. A 7 flash means "joystick is out of neutral".
Sep 20, 2014 | Health & Beauty
Shoprider Powerchair has full charge and turns on. Once I touch the joystick it shuts off. No flash code is present. Verified all connections. Replaced joystick, problem still occurs.
Hi , when you say shut off, you mean like it been turned off ? if so check the connector going into the controller , the issue could be with the controller connect, not the joystick end if it's been replaced...
Regards
Rob
www.gewizrepairs.co.uk
Jan 21, 2014 | Shoprider Streamer Sport Power Wheelchair...
Flashing wrench 9 times
Lester - so many issues. Take it to a dealer.
9-Flashes means comm fault - check joystick wiring harness.
Nov 01, 2013 | Electric Mobility Invacare Pronto M41...
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy select contol panel all leds flash 7 times. what does that indicate?
This problem may depend on which main controller your chair has fitted. It should be a Penny & Giles GC controller. US versions should have a GC3 whilst here in the UK, it would be fitted with a GC2. However, the diagnostic flash codes for these two controllers should be the same. The reason im slightly confused is that you say 5 flashes mean your charger is connected at power up, when in fact it should be a Right Motor Wiring Fault. 9 flashes is indeed a Solenoid Brake Fault, or in other words, the wheelchair is in 'Free Wheel' as you have described. Therefore, IF your controller is in fact a Penny & Giles GC, 7 flashes would mean a Joystick fault. There is not much you can do to diagnose this other than checking connections between the Joystick and main controller. If these are OK, it is likely that a new Joystick controller will be required as having these fixed is usually not cost affective. Hope this is of some help to you.
Jan 27, 2013 | Pride Jazzy Select 6 Indoor Power...
Jet 3 flashes "code 7".
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
Nov 30, 2010 | Jet 3 Ultra Power Chair
It just flashes all the time when it's on and won't move. pride 7. what error do you get when the joystick goes bad? can I replace the joystick myself?
These are called VSI error lights. The VSI is the fancy name for your electronic controller. [Basically the joystick :) ] The number of times they are flashing, gives you the codes of the problem. The system locks until it is sorted to prevent injury. Follow the link below for the User Manual for your model. First check page 37 to see if it isn't just locked, then page 38 for code meanings. If its flashing lots, most of those high numbered ones are just a case of checking things are all plugged in tight.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Jazzy%201103%20Ultra%20Owner%27s%20Manual.pdf
Hope this helps.
Apr 29, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Health & Beauty Logo
60 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
