Question about Sony MegaStorage CDP-CX355 300-Disc CD Changer
How do I remove the cover from my cx300. I already removed the scres
    Genius:
  • Sony Master
  • 1,054 Answers
It should just lift off
Posted on Apr 22, 2014
  • Cal Oren Apr 24, 2014
    I have done it and don't recall it being particularly complicated. I bet it slides backwards first, then lifts off. Or perhaps you have to lift one edge first then slide and lift off. This is the way most computer case covers are removed.
Replace pull cord for ryobi ss30 weed trimmer
There are 3 Scres that hold it in place
Apr 07, 2013 | Ryobi Garden
Compact Disc Player CDP-CX300 not reading discs
Probably have to get the laser replaced as long as all the mechanics are working to load the disc.
Jan 02, 2013 | Sony CDP-CX300 CD Player
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
Removal of gas tank housing from husqvarna 41 chainsaw
Removal of the tank is not too difficult,start by removing the guide bar and chain, remove the top cover of the saw, now remove the fuel hose from the carb, remove the four screws retaining the starter cover, here you will have two self tapping screws, and two machine screws, the machine scres go into the anti vibe mounts, be sure to get these the correct way around when re building, now turn the saw over, remove the allen screw securing the chain catcher at the bottom corner of the crankcase, this scrtews into the front anti vibe mount, now remove the screw at the top rear of the crankcase, ans remove the small orange plastic cover, this screw goes into the rear anti vibe mount, now pull the whole tank assemblt down and away from the saw, there is no need to remove the top handle, this will come away with the tank.
Aug 22, 2011 | Husqvarna Garden
Canon2018
Send the e-mail, and ill send it to you.
But shortly:
Remove left door on copier.( Remove plastic cover left from the door ( 3 screws ), disconnect the wires if you have duplex, unscrew the screw on black plastic tape, with pliers pull up the metal pin wich acts as upper hinge.)
When you removed the door, from left side beaneth the fixing assy you will see smal black cover with one screw, remove it so that you can disconnect the connector of fixing film assy, from the right side of fixing assy, remove the cover ( that is the cover wich is long and covers the door locking mechanism - two screws ) Disconnect the 3 conectors. Unscrew the scres that holds fixing assy left side and right side.
Pull towards the fixing assy.
Dismantle it how you see it, but you need to remove the green handle, and remove the axis that have on both side plastic pressure realese pins.
Pls. rate
May 13, 2010 | Canon Office Equipment & Supplies
How difficult will it be for me to put a new screen on my acer 5315-2153 laptop? The original screen has been crushed. I already know that the computer is still working just fine otherwise. Thanks, Val
The job is very easy and needs you to remove the covers fromthe scres in the scree cover mask. Remove the mask and then unplug the screen from the ribbon driver cable. Unscrew the 8 securing scres around the ASlu frame and then lift out. Reversal is the opposite process. I just did one todayand it took under 15 mins to complete and power up the Acer. Just take digital photos at each stage so you dont forget where things go or what you have done.
Sep 30, 2009 | Acer Aspire 5315 Notebook
How do you replace the screen or lid of the 9100
You need to remove the power button cover and the left and right corners. Unplug the connectors that go to the screen. Next turn it over and remover scres marked letter P. The allows the hinges to com up and the whole lid lifts off.Now pop out the rubber buttons around the screen, the scrwes are hidden underneath them.
Feb 27, 2009 | Dell Inspiron 9100 Notebook
Removal of cover
There a number of screws, remove the brush block, there are acouple of screws there, Then on each bottom edge is a screw sit deep in a hole. There are some more scres, you can see them from the bottom, 2 of which are close together and longer, these help hold the turbine. turn it over, there is a screw near the edge of the noozle, it should lift off, the 2 posts near the back are just pushed in and should come free. The turbine will have a couple of tubes and 2 screws on the front of it, then it come come off.
Jun 28, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Putting a new door on my Sony CDP CX300
u must remove the broken old door carefully by removing the rubber belt which is connected to the dc motor and bear by there be a white colour plastic which holds the door u must remove that and then u must put replacement & once again u must connect those all properly so it s difficult... just visit technician....
Feb 02, 2008 | Sony CDP-CX300 CD Player
CDP-CX300
Get a service manual or pro to get this taken care of. It's a timing issue..accordianman
Nov 24, 2007 | Sony CDP-CX300 CD Player
Sony MegaStorage CDP-CX355 300-Disc CD Changer Logo
111 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
