Question about Konica Minolta Office Equipment & Supplies
Cs pro copier EP300
How to clear co200
  • Konica Minolta Master
  • 6,161 Answers
Open the front door in the middle relase the lever now, see a shaft you can pull well that shaft is clean system for two very fine wires the carry several thousand volts during the copy process not with door open push down on assy and pull it out. replace the two wire don't lose the springs if the you may also have to replace the two end of that assy, if after replacing the wires, because after years the plastic breaks down due the HV and allows the HV to go to the ground. Open close the front door to reset.
try this site
there called charge corona wires mite buy a few!!! they are very easy to break.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Dec 30, 2015
firecontrol7
  • 6161 Answers
SOURCE: cs pro minolta copier displays a code co6
Open close the front door if that does not work and the code comes back check you scanner cable underneath the large glass for the documents
Posted on Jul 19, 2009
SOURCE: how to clear M2 on minolta EP 4000/5000 cs/pro copier
how can i clear m3 code on minolta 4000 copier
Posted on Dec 12, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Posted on Mar 16, 2010
  • 1294 Answers
SOURCE: MINOLTA CS PRO EP3000 COPIER. The copy is too dark
Clean the optical parts:mirrors,lens and the charge and transfer/sepaRATOR CORONAS.
Posted on May 22, 2010
  • 1294 Answers
SOURCE: error code c0510 for a minolta cs pro
Change the fusing unit heatre lamp thermistor,reset the error code.
Posted on Jan 23, 2012
How to clear a code
Sir/Mam
Open close the front door. if it comes back the charge corona wire above the drum or the transfer & separation wires are the problem. The charge wire is above the drum have to remove the drum section to see it they are very thin gold plated wires that place a electrical charge on the drum prior to the image being placed on the drum.
The Transfer and separation wire are directly below the drum Transfer allows the image to be placed on the paper as it comes underneath the drum and above this very thin gold plated wire, The separation wire the second one prevents the paper from sticking to the drum. The xfer/sep assy. wires are located directly under the drum. then are very thin mite be broken. Grounding the High voltage. pull down and pull out the assy. to check it. There is cleaning handle try pushing it back and forth. If they are broke replace tem very carefully. Percission Roller may have them
Apr 21, 2014 | Minolta EP4000/5000 CS/PRO Copier
Ep3000 how to clear a code co200
Sir/Mam
If available
Cs pro copier
try this site
Apr 21, 2014 | Konica Minolta Office Equipment & Supplies
Cs pro copier EP 3000
try this site
Tolong solusi cs-pro 5000 sering please wait
replace the drum and the developer and cleaning blade while it is out. make sure that counters for drum and developer are cleared and that F 8 and F 5 are run after new drum and developer are installed.
Aug 13, 2011 | Minolta EP4000/5000 CS/PRO Copier
Ink fall in down inside minolta cs pro ep 1054
Get the developer replaced. and developer unit cleaned. Have a Konica Minolta tech come out and clean the entire machine replace the required parts such as Developer, clear the counters and run the required F8
Oct 31, 2010 | Minolta EP1083 CS/PRO Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
23 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
