Question about Konica Minolta Office Equipment & Supplies
Cs pro copier
How to clear code CO200
  • Konica Minolta Master
  • 6,161 Answers
Open the front door in the middle relase the lever now, see a shaft you can pull well that shaft is clean system for two very fine wires the carry several thousand volts during the copy process not with door open push down on assy and pull it out. replace the two wire don't lose the springs if the you may also have to replace the two end of that assy, if after replacing the wires, because after years the plastic breaks down due the HV and allows the HV to go to the ground. Open close the front door to reset.
try this site
there called charge corona wires mite buy a few!!! they are very easy to break.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Dec 30, 2015
  • 18 Answers
SOURCE: resetting code on a copystar cs-1620
what code? many codes to be reset such as 1087 1087 then enter163 to reset fuser. you need to know what your resetting first, some machines used 096. let me know what you resetting. rrralf
Posted on Feb 03, 2008
  • 3 Answers
SOURCE: c0071 error code minolta cs pro 2080 copier
this code is for toner motor rotation abnormal timing. check for any loose toner inside the toner hopper rotational path, clean the sensor for toner motor. check the toner bottle inserted is for the same model
Posted on Jun 16, 2008
  • 87 Answers
SOURCE: Minolta CS PRO black/white copier has error code
COF30 THIS CODE SHOWS THAT THERE IS PROBLEM IN AUTO TONER SENSOR.MAY BE IT IS DIRTY .CLEAN IT PROPERLY .OR REPLACE IT.PROBLEM WILL BI REMOVED.DO NOT FORGET TO RATE A SOLUTION.MIAN JEE
Posted on Feb 22, 2009
SOURCE: how to clear M2 on minolta EP 4000/5000 cs/pro copier
how can i clear m3 code on minolta 4000 copier
Posted on Dec 12, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: my copier minolta cs/pro ep 2010 does not
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Posted on Mar 20, 2010
How to clear a code
Sir/Mam
Open close the front door. if it comes back the charge corona wire above the drum or the transfer & separation wires are the problem. The charge wire is above the drum have to remove the drum section to see it they are very thin gold plated wires that place a electrical charge on the drum prior to the image being placed on the drum.
The Transfer and separation wire are directly below the drum Transfer allows the image to be placed on the paper as it comes underneath the drum and above this very thin gold plated wire, The separation wire the second one prevents the paper from sticking to the drum. The xfer/sep assy. wires are located directly under the drum. then are very thin mite be broken. Grounding the High voltage. pull down and pull out the assy. to check it. There is cleaning handle try pushing it back and forth. If they are broke replace tem very carefully. Percission Roller may have them
Apr 21, 2014 | Minolta EP4000/5000 CS/PRO Copier
Ep3000 how to clear a code co200
Sir/Mam
If available
Cs pro copier EP300
open the front door in the middle relase the lever now, see a shaft you can pull well that shaft is clean system for two very fine wires the carry several thousand volts during the copy process not with door open push down on assy and pull it out. replace the two wire don't lose the springs if the you may also have to replace the two end of that assy, if after replacing the wires, because after years the plastic breaks down due the HV and allows the HV to go to the ground. Open close the front door to reset.
try this site
Apr 21, 2014 | Konica Minolta Office Equipment & Supplies
Cs pro copier EP 3000
try this site
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
Code C0500
hold down exposure key (<) while turning on power, u-1 will display. prss start, select clear mode, prss clear/stop
Dec 15, 2008 | Minolta EP1030/1030F CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Jun 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
15 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
