Question about Konica Minolta Office Equipment & Supplies
Cs pro copier EP 3000
Malfunction Code Co200 how do fix it
  • Konica Minolta Master
  • 6,161 Answers
Open the front door in the middle relase the lever now, see a shaft you can pull well that shaft is clean system for two very fine wires the carry several thousand volts during the copy process not with door open push down on assy and pull it out. replace the two wire don't lose the springs if the you may also have to replace the two end of that assy, if after replacing the wires, because after years the plastic breaks down due the HV and allows the HV to go to the ground. Open close the front door to reset.
try this site
there called charge corona wires mite buy a few!!! they are very easy to break.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Dec 30, 2015
  • 3 Answers
SOURCE: c0071 error code minolta cs pro 2080 copier
this code is for toner motor rotation abnormal timing. check for any loose toner inside the toner hopper rotational path, clean the sensor for toner motor. check the toner bottle inserted is for the same model
Posted on Jun 16, 2008
claudiomn
  • 10 Answers
SOURCE: my Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Posted on Jan 17, 2009
Cogz
  • 1326 Answers
SOURCE: code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
Posted on Feb 07, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: i have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Posted on Oct 17, 2009
SOURCE: how to clear M2 on minolta EP 4000/5000 cs/pro copier
how can i clear m3 code on minolta 4000 copier
Posted on Dec 12, 2009
Display error co500. Please help?
Open the front door, with power on. upper left small access cover remove and press trouble reset switch if the code comes back DO NOT RESET means a problem with the fuser (The hot Part) it can catch on fire that will ruin a perfectly good day. Have a tech come out look at it. He need to be old school that is a legacy Minolta machine, Now KonicaMinolta. For parts try this site.
Parts such as fuser lamp, thermistor and thermostat
Jun 17, 2015 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Access code needed
Access to what service mode or admin mode, pin#
Mar 29, 2015 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Minolta cs pro 2030 C00 CODE SHOW PLZ HELP
Missing two numbers on the end of the 00 is it 0070 or 0000?, 0000 is main motor drive 0070 is toner bottle issue.
Mar 03, 2015 | Konica Minolta EP 2030 3000 Toner 2-410...
What is Error C0110 for ep 4000/5000 cs pro
Could not find that code in the service manual how about C0000 or c-0010
Apr 18, 2012 | Minolta Office Equipment & Supplies
Detaile of Code of Minolta Ep 6001 coper
pleas send me cs pro 6001 code 611 salvation
Feb 12, 2011 | Garden
Where can I download service manual for Minolta pro ep 2030. Free if possible
i can download it for you send me an email to forward it to you
Jan 31, 2011 | Minolta EP1083 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
