Question about Fujitsu Fi-4120c2
Error 2148285 NO twain , or other scan error
  • Fujitsu Master
  • 3,512 Answers
What driver are you using no twain suggests that the driver is not twain compliant. You may need to update the driver with the correct operating system like windows (whatever it is) or is it MAC OS .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/fi-series.html
Posted on Apr 29, 2014
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
I have HP Officejet J3680 All in one I wanted to scan a document but it is saying there is not option..
canning functionality from the LJ3380 and CLJ2840 series All-in-One devices may not function until the correct Twain Data Source is selected by the user. This can be done by attempting to scan from the foundation scan executable "hppscan2.exe ".
  • For the LJ3380 series this is located in C:\Program Files\Hewlett-Packard\LJ3015_LJ3020_LJ3030_LJ3380->hppscan2.exe
  • For the CLJ2840 this is found in C:\Program Files\HP\Digital Imaging\bin->hppscan2.exe
When the "hppscan2.exe " is launched from this location where it resides, a dialog box will open with a "Select Source " box listing the installed Twain scanning devices available. If this box is not seen, then there is only one Twain device installed. In some instances user input is needed to chose the "correct" Twain data source for scanning to be successful from the LJ3380 and CLJ2840 series devices. If the incorrect Twain data source is selected- an error "Cannot initialize device " will be seen.
Oct 27, 2010 | HP J3680 Officejet All In One Printer
I keep getting a Twain error, how do i get it to work?
The Twain driver is used to scan images into the computer.
It is either corrupted or deleted.
Reinstall the Canon scanning software, it includes the Twain driver.
Oct 18, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
I have installed the UE 404090, but cannot scan to my PC. It says no twain compliant found. If I press scan/file on the machine it says select destination _ what can I do there?
Have you at some point installed a second scanning device on the system..
Reason being TWAIN is configured slightly different by every manufacturer to optomise the working of their hardware.
It some cases when you install a TWAIN device for Scanner A this can interfere with Scanner B
Usually its because your trying to use TWAIN(scanner A) on Scanner B
Make sense?
Make sure (if you have installed another scanner device) that you are using the TWAIN software that came with .
You might need to reinstall the entire set up from beginning.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 06, 2009 | Panasonic PanaFax UF-8000 Laser Fax
I need a twain driver
I can understand that u get TWAIN driver not installed or required error on PC while scanning.
Twain drivers are imaging driver which are bundled with complete software.
Incase if you try to replace just the twain driver it may corrupt anoth files.
It is always advisable to clean the computer and reinstall the complete software.
Jul 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
Twain Complient
twain data transfetr error help please
Oct 20, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
On Epson Perfection 1250/165o series ,Twain error,component ICM-2, File Group EW-Profilew ,File <sxICCPath>,Error the filename,directoryname or volume label systax is incorrect.
jkatonah,
Power off the Epson. Your twain software did not install correctly.
Uninstall the software you installed for the perfection 1250.
Go to Epson's link listed below & download the twain driver.
Pick your operating system & choose the twain driver.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14548&prodoid=6464128&infoType=Downloads&platform=All
Re-start your system & try again.
Good luck & Thanks for using FixYa.
please vote..
Mar 08, 2008 | Computers & Internet
Fujitsu Fi-4120c2 Logo
106 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
