Question about Invacare Pronto M51 Power Wheelchair
What is the joystick flash code meaning of hoveround Teknique GT power wheelchairs
  • 175 Answers
Http://www.hoveround.com/power-chair-and-power-scooter-downloads
Click on the link and go to the Hoveround site, click on GT to download manual.
Posted on May 08, 2014
Hoveround Teknique XHD had a flat changed inner tube put back on now the motor spins but the tire stays still
The shaft is turning and not the wheel, that means the key is missing off the shaft. or the freewheel lever needs to be flipped into drive mode.
Oct 04, 2015 | Hoveround Teknique XHD Power Chair - Used...
Pthe joystck frame is in a bent down position. How do I fix it
It would seem that the support frame is bent. Remove joystick and support from arm. Straighten support and reassemble.
May 09, 2014 | Hoveround Teknique XHD Power Chair - Used...
My hoveround light flash and then goes off wont move.it is in forward gear and the batters are ok.thank Charles
The number of lights that are flashing will indicate what the problem is related to.
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. Try resetting your brakes to see if that will help reset the system (makre sure the power chair is turned off first.) If your insurance purchased the power chair for you, they may also cover the repairs; contact Hoveround for an appointment.
Dec 08, 2010 | NRS Hoveround MPV 5 - Used Power...
I have a hoveround mpv4 that has a fault code of 8 bars I rang wires out from controller to j-box and everyone was ok if its the board where do i go to get a new one and how much do they cost.
bbass you will have to order a joystick from Hoverround or a hoveround provider if you want a new one. You can also check on e-bay or with a provider that might have a good used joystick. cost could be as much as 600.00 Hope this helps
Oct 17, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
When I power up my MPV4 I get a 9 flashing led error. Is there something I can do to rectify this error?
rakoble the 9 flashes error code can indicate the brake lever not in drive mode or if you have the electric seat its not all the way down or finally a controller problem and on the Hoveround thats the joystick. Check the brake levers and the seat if you have that on your chair. If the first two are ok then its the joystick and you'll have to get a new one. Hope this helps
Sep 23, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Put in drive controller just blinks
Make sure the release levers are up all the way (in front - above the footplate). Shut power off and try chair again. If the entire row of battery lights on the joystick controller are still flashing, you need a new joystick. Contact Hoveround or The Aftermarket Group online who will qoute you a repair cost. It will probably run anywhere from 300 to 1100.
Aug 22, 2010 | NRS Hoveround MPV 5 - Used Power...
The speed control light goes back and fourth on the console.
If the lights are chasing left to right then you are in inhibit mode meaning a charger is attached or there is a problem in the joystick with the inhibit functio. Right to left chasing I think means you are in freewheel. Turn the Power off and reset the levers in front on the chair then turn the power back on and hope the lights are steady and the chair will work. If this doesn't do it maybe you are in lockout mode. If you have the manual for this chair it should explain how to get out of "lockout". If not try turning the power on and within 10 seconds push the joystick straight forward and hold until you hear a beep then immediately move the joystick to the rear and hold until you hear another beep then release joystick to the center. This should get it out of "lockout" Hope this helps!!! Of course you could always call Hoveround and ask for tech support to help with this. Checkout their website for phone number Hoveround.com
Aug 19, 2010 | NRS Hoveround MPV 5 - Used Power...
Have a Hooveround Teknique FWD wheelchair,
Five flashing lights indicate Right Motor Wiring Trip- The right motor has a short circuit to a battery. Check all the connections and leads between the right motor and the battery.
May 15, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Have a Hooveround Teknique FWD wheelchair, replaced circuit board in joystick, checked all wiring, but 5 lights rapidly flashing. Any ideas please
5 bars indicate a short circuit from the right motor to the battery. Check all the connections and leads between the right motor and the battery.
Mar 27, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Hoveround mpv4 does not work led flash when turned on. 3 red 4 yellow and 1 green leds. the brakes, motors and wires have all been tested and work. Any Ideas?
This 8-light code is a joystick controller problem. It is an internal problem with the circuit board located inside the joystick. The entire joystick assembly would need to be replaced in this situation. If you are in need of a joystick, I have several for sale.
Jun 21, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
Invacare Pronto M51 Power Wheelchair Logo
133 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
