Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos Electronic Dryer gave F code after power outage
hunter19_46m
  • 7482 Answers
SOURCE: maytag bravos dryer makes loud grating sound
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 02, 2009
SOURCE: ''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Posted on Dec 27, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Posted on Jan 11, 2010
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Posted on Mar 18, 2010
Testimonial: "Thanks so much!"
mkh5094
  • 145 Answers
SOURCE: maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
Posted on May 02, 2010
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
My bravos quiet series 300 will not turn on. what could be wrong
Check for power first must have all the juice one side of electric can be down. check door switch or replace Dryer electronic control board Part #: W10222206
Feb 20, 2015 | Maytag Bravos MEDB200VQ 29" Electric Dryer...
Maytag bravos electric dryer powers on but will not run no codes on it, just wont run
Check that door is fully closed. Or turn on dryer and manually press the door switch to see if that works. If not than it is that switch. A thermoswitch will also do that
Mar 30, 2014 | Dryers
MAYTAG BRAVOS DRYER CODES FLO, CO WON'T START AFTER STORM
I have the same problem. Technician recommended to replace main control board - didn't help. Now I ordered the user interface board. The self test results in C0 code which stays till reset.
Jul 04, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Had a power outage and believe a surge was sent through our dryer. Breaker is fine and have the correct voltage. The board lights up but no display in the estimated time remaining and will not start....
Ours did the exact same thing after a power outage. Our repair guy has been out 3 times, first he replaced the power board, then the motor and blower! He has to come back again with a moisture sensor now. Im begining to think he doesnt know what hes doing! By the time hes finished I will have replaced all the inside parts, Im afraid. Our dryer is only 16 months old. Did you ever get yours going? Any advice?
Jun 12, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
