Question about Cambridge Audio DVD89 DVD Player
Cambridge dvd98 not powering on
Will not power on
Cambridge azur 540r receiver just stopped working. no power showing to on/off led.
Could have a problem in the power supply section. Check for open diodes and bad capacitors.
Sep 27, 2015 | Cambridge Audio Azur 540R Receiver
Why does my Cambridge Audio Azur 851W power down even when a signal is operating.
amps like this only power down when there is a problem with the amp, usually a shorted output stage, but could also be shorted speaker wires or damaged speakers, it's a self protection mechanism
do you get sound from both speakers before it powers down?? if you do it is definitely an internal problem so take it to a repair facility,,,
if not check the speaker cables & the speakers themselve
Feb 22, 2015 | Cambridge Audio Audio Players & Recorders
Service center philippines
I am going to guess these are fairly old speakers. I would recommend getting a replacement system.
Mar 22, 2014 | Cambridge Soundworks Audio Players &...
Cambridge Audio Azur 640R AV Recorder won't switch off
Sounds like the unit is victim of a power surge. The power control board is probably damaged. You will be better off replacing the amp as having it repaired will cost more than replacing it.
Mar 02, 2014 | Cambridge Audio Azur 640R 7.1 Channel...
Cambridge audio Azur 540a repair
Open your amplifier then find the power relay inside push the power button and observed the relay if active. If so the measure the voltage on large capacitors. But if the relay is not active check the relay drive transistor and the blocking diode across the coil.
Oct 05, 2012 | Cambridge Audio Azur 540A Amplifier
What ac/dc adapter do i use with the creative
check this one, they have power adapter for cambridge soundwork dock
http://www.findpowercord.com/ac-dc-power-adapter-for-cambridge-soundworks-i-dock/
Oct 24, 2009 | Creative Technology Cambridge SoundWorks...
CD Player does not load CD
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Oct 12, 2006 | Cambridge Soundworks 740I CD Player
Cambridge Audio DVD89 DVD Player Logo
32 people viewed this question
Top Cambridge Audio Televison & Video Experts
Electro Med Services...
Are you a Cambridge Audio Televison and Video Expert? Answer questions, earn points and help others
