Question about Garmin nuvi 500 GPS Receiver
Garmin gpx files
It combines two separate bike rides into one file. For example, I pre-road a race course one day. Then 24 hrs later, I raced the same course, but the files were combined into one showing I rode the course twice in 43 hrs. Moreover, it combined and averaged all my data. How do I stop this?
    Scholar:
  • 189 Answers
After you are finished one bike ride, look for the settings option to choose "end this ride" or to save it. This way when you do another ride it will start a new separate gpx file.
Posted on Jul 12, 2014
  • 26 Answers
SOURCE: Memory full
****HELPFUL HINT**** Before you do anything with the Garmin unit, you might want to make a folder somewhere on your computer and name it something like NUVI CONTENTS. Then copy and paste or drag and drop, however you want to do it, all the contents of your NUVI. This way if you do something you didn't mean to, like delete a language, you can just put it back in.
Now what you need to look for are 3 folders, one is the HELP folder which is pretty useless once you get the hang of the Garmin unit. As a matter of fact I never even used the HELP button on the Garmin unit, because it's so easy to use.
The other folder is the VOICE folder, open it and start deleting the languages you are not likely to use or need. Make sure you DO NOT delete American English, unless you want to stick to British English. Of course I am assuming you need English, but regardless it goes for whichever language you want to keep. Assuming you are keeping American English these are the names of the files you need to keep in the VOICE folder english_american_.sum and English_American_.vpm.
The last folder is the TEXT folder, open it and delete all the files if you want. American English is the default so it won't go away, but regardless you'll have a back up anyways...RIGHT? LOL
I hope this helps you, and if you have any questions lay them on and I'll see what I can do for you. But I will say that I just bought my Nuvi back in April of this year so I am still learning a lot about it. I am working on tweaking the XML file so that it will ready more than 1 map on the SD, right now we are limited to 1 map per SD card.
Posted on Jul 19, 2008
toddg
  • 171 Answers
SOURCE: Unable to send and open
Currently, the POI Loader only supports CSV files because that is the format that most data vendors support. POI Loader may support additional formats in the future.
MapSource only supports .mps, .gdb and .gpx files. You can save files as .txt files if you wish to use this data in other applications.
Sadly Garmin does not produce any software which can convert .txt files.
However, this maybe possible with GPS Utility. Please note GPS Utility is not Garmin software and Garmin does not support this. Click on the following link for more information:
www.gpsu.co.uk
Posted on Oct 13, 2008
  • 3 Answers
SOURCE: New Garmin Legend
dont worry, just do it, you can always get the old stuff back through the garmin website
Posted on May 31, 2009
  • 81 Answers
SOURCE: cant delete gpx files from 705 edge memory. done
Only one idea ... Perform hard reset. Garmin devices have often data corruption issue, that can only be solved by return to factory settings :
Device powered off, press and hold mode and Power on buttons for 10 seconds, then pulse press lap/reset button.
You will be asked for confirmation, confirm, your device should be OK then.
Also update the firmware, you'll get last fixes for data corruption ... (does not mean there are none remaining ...)
Posted on Sep 25, 2010
  • 81 Answers
SOURCE: I am charging the Garmin Edge 305 for 24 hrs or
Discharge completely device then charge again for 8 hours.
If not working, then attempt Soft reset :
Hold mode and lap/reset for 10 seconds then release.
Start the device then by long press on start. DEvice should start and charge then
Posted on Sep 26, 2010
Who often do i change the oil on a kx250
If you race this bike then I would suggest at the end of every full race meet dump the oil and filter as apart of the clean down to put away for next race day routine obviously fill it back up when due to race next
If your just recreational use and not going on the rev limiter all day long then about every 2 - 4 hours of running time would be OK
simple rule of thumb with the four stroke Motocross bikes if you love the bike and you can afford it change the oil as much as possible you cannot change to often in my opinion (just don't over tighten the sump plug just nipped up is fine)
cheers mate happy riding
May 24, 2011 | 2005 kawasaki KX 250 F
Tip
Garmin POI, GPI, GPX, GDB and CSV and how not to be confused
GPX or CSV file can be converted to the proprietary Garmin format GPI format (Garmin Points of Interest) format using the Garmin POI loader v2.54 OR use the one bundled with the Garmin Map Source v6.15.11 at the time of posting if there is also a BMP file of the same filename then this will be added to the Waypoints Symbol.
If you put all your POI that you want to be added to the Garmin POI then place all them in the same folder prior to starting the POI Loader and they will be placed into sub-menus otherwise it will select the single file entries only.
However the Garmin Mapsource can't open this GPI format it is specifically for the SATNAV Device only open GDB, MPS, GPX and LOC files can be opened as standard. There are two ways that I know of that will convert this GPI back into CSV or the POI format if required you might like to open the POI content in the Map Source program.
First this can be done using GPI2GPS it does however cost 15 EUROs or its older brother GPSConvertor for an extra 20 EUROs will convert to all formats for all makes of device including Tom-Tom, Garmin and many others.
Secondly you can convert POI file in CSV format directly to GPX (exchange format) using the excellent GPXtoPOI Convertor v1.1.8 then import directly into the Map Source if you also want to use BMP that has been downloaded in Map Source you can replace the 8 default custom waypoint symbols located on your computer with your own or from the Tescos.ZIP file in this example that contains the CSV and BMP.
You can open these symbols with a graphic editor and use them as templates for creating your own symbols.You can add up to 64 custom waypoint symbols. These symbols must be in .bmp format and must be named numerically from "000.bmp" to "063.bmp." Custom waypoint symbols can be 16 x 16 pixels (small) or 24 x 24 pixels (large) and up to 32-bit color
Also check out my other POI tip HERE for help on how to create your own BMP's for use with your Garmin using Adobe Photoshop
It will also convert any GPX format into CSV format for use with the POI loader using the other button on the menu maybe this program would be best called GPXtoCSV instead to avoid confusion
And this one I saved for last If you want to transfer images from the Garmin use xImage and have your Garmi SATNAV connected.
For a full list of all POI sources then visit the Gamin POI Source another great website full of loads of useful tools is www.freegeographytools.com
If you are unable to use xImage it means that you unit is not compatible for example the Nuvi 250 will not be found and you may see this window
on Apr 18, 2010 | Garmin nuvi 250W GPS Receiver
Help me choose the travel/bike I need . I'm looking at two bikes. One is a 4 inch travel XC oriented frame and the other is a 5 inch travel. I ride mostly in Ohio, but travel for Xterra triathlons and...
I'd go with FTM. More comfortable, it can still use for racing. Give them both test ride if possible. I have both Motolite and RX, I'd take ML any day.
That said most XC racing course is doable with HT or XC FS, so if racing is your primary goal then RX.
Dec 21, 2010 | Cycling
My honda cr 125 motcross keeps going through spark plugs,using correct fuel,runs well for an hour or so.
Hello assuming there were no carburetor jet changes and your bike is running to rich. or you have realy dirty air cleaner.
Fouling plugs due to to much oil could be the wetside oil seal needs replace because it is letting your trans oil enter the crancase or you have worn crankshaft roller bearings.
May 25, 2010 | 2002 Honda CR 125 R
I will be riding a 340km 24 hr mtb stage race consisting of 6 stages in dec. How do I manage charging of my Garmin Edge 305 over what will be some 18hrs of riding with short breaks between stages?
Bring a portable PC device plus your USB cable, and a charged battery on your PC, Edge will charge when connected to PC via USB.
Any other powered USB source would also help charging.
However for a 24 hours trip, it is worth downloading your races on the PC and clearing memory, as otherwise memory will get full and waypoints will stop register.
Nov 09, 2009 | Garmin Edge 305 GPS Receiver
Bikes
You are in the wrong area of FixYa, but I can make some suggestions.
It depends upon what type of bike riding you want to do.
If you want to ride bikes over rough terrain and cross country then you need a mountain bike.
If you want to ride bikes on roads only then a road bike is what you need.
A mountain bike can be used on road surfaces but a road bike is not suitable on rough terrain.
If you want to bike race, then you need a racing bike, these are very light and expensive.
It is best if you go to a large bike shop and speak to the sales person or go to a bike club and ask questions. This will help you to decide what type of bike will suit you and your needs.
Oct 28, 2009 | Computers & Internet
Iv got a 2005 yz 250 stock whats the best way to hot it up
hot it up? you mean make it go faster ? wow it's a realy quick bike right out of the box if the bike seems to be lacking power easy check is the air filter ...pristeen like so clean you would eat off it? 2005 ...when was the last time the top end was done ? about every 30 hrs for a two stroke half of that if you are racing it by racing I mean getting on a motocross track and riding with other guys about your skill level till you have arm pump that makes you wish you had stayed home. if the above conditions have been met then a pipe is probably your most logical choice don't wast time and money on the engine making it high compression and needing race fuel 100++ octane is a total waste for all but the elite riders and it makes the bike unreliable and fussy "like a hot blonde pretty to look at but high maintence" Good Luck & Ride safe
Oct 12, 2009 | 2004 Yamaha YZ 250
Can we **** on a bike?
Riding a bike can lead to impotence from the seat pressing on the base of your *****. So get off the bike and go in the woods. :)
Oct 11, 2009 | Shimano 24 Speed Road Racing Bike Bicycle...
Engine oil
Hi, I am a lifelong biker and I can tell you this is strictly a personal preference thing based on how and where you ride. In the owners manuals of almost every bike you will find an oil chart based on temperature if the average temp where you live is below 60F then you want a thinner weight oil and so on. If you race you want maybe a synthetic racing blend. So the bottom line is if you road race in Phoenix vs the person who commutes in New York you would use an entirely different oil. My best advice is to contact your local bike shops or bike clubs and tell them how you ride and they will tell you what they sell locally. Good Luck!
Jan 29, 2009 | 2003 kawasaki ZX-6R
Garmin nuvi 500 GPS Receiver Logo
60 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
