Question about KOBO, INC Kobo Glo
Kobo e reader
Screen went blank during software update
How do I change my password?
Pat, Go to Kobo.com, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
kobo com help Resetting or changing your Kobo password
How to reset and factory reset your Kobo
Kobo Tips and Tricks for new Reader Owners
May 26, 2016 | Kobo Glo E-Reader
Kobo won't turn on
https://koboproblems.wordpress.com/2013/07/15/how-to-reset-and-factory-reset-your-kobo/comment-page-1/?hc_location=ufi
you have looked how to reset your device
you may loose all settings but im sure it has a cloud backup as most do
good luck
other than this perhaps try to wait till it powers off from very low
bat
i found a few links to forums
google search for links
kobo reset
or factory reset
Mar 30, 2015 | Kobo 6" eReader Touch Edition
My Kobo Aura HD's comfort light is off and I can't find a way to turn it back on.
On the top of the e-reader, to the left of the on/off slider (looking at the screen) there is a push button on/off switch for the light. Once the light is turned on (and there is a 'star' symbol on the screen, the brightness can be adjusted by touching the 'star' and using your finger to slide the brightness control).
Mar 19, 2015 | Kobo Aura HD E-Reader
Kobo won't turn on, screen blank
This can happen if the battery is very, very flat. Try charging it overnight.
If charging it doesn't help, try using a paper clip in the reset hole to force a factory reset (you may lose any user-installed books).
Mar 01, 2015 | Kobo Glo E-Reader
I am reading a book on my new Aura Kobo ereader, the print is too small, how do I get back to menu to change size of print?
No menu required. Just use two fingers on the screen and slide them apart. Be careful, it's easy to get very big, very quickly.
To get smaller slide two fingers together on the screen.
Feb 20, 2015 | Kobo Aura E-Reader
Kobo ereader fell on floor just have a blank screen
the lcd backlight called a CCFL tube much like the stip lights
has becomes disjointed or has cracked
if the screen survived uncracked then its worth getting it looked at by someone who knows LCDCCFL and where to gain a replacement
Dec 21, 2014 | Kobo 6" eReader Touch Edition
My Kobo glo, after charging it, went to very small print, and the words don't fit on the page. How can I reset it?
On my kobo, I have to touch the middle of the screen to get the toolbar to pop up at the bott of the screen. You should the find the usual icon.
Oct 22, 2014 | KOBO, INC Kobo Glo
My Literati will not update or download books.
Hi, Pam. I feel your pain! I had a Literati for about two years, and when it died a couple of months ago I pounced on a new one from a reseller. Alas, the Literati website no longer exists, so the new reader tries and tries to retrieve that critical update but always fails. Too bad, because the reader as shipped is very buggy (doesn't have all the font sizes/options, can't log in to Kobo [I can't select the login button once I've put in my password], can't even recognize the SD card). Calls to Sharper Image booted me to Kobo; Kobo's very nice e-mail said that they can't help with hardware problems and gave me the MerchSource website, along with a couple of phone numbers. The MerchSource website gives only a phone number--for Kobo. So I called.
I just got off the phone with a very friendly young man who informed me that, sadly, they do not have that software update lurking anywhere. He apparently scored a $10 Literati somewhere that he's experimented with so he could understand his customer calls, and the only thing he's found is this discussion site. He says he's had good luck using Adobe Digital Editions (discussed on that site) to get things onto the reader. I haven't tried it yet (still at work), but there are detailed instructions given.
I hope this helps!
Mar 05, 2013 | Sharper Image Literati Reader 16375680042...
Lookbook wireless reader manual
I am having a problem get my lookbook hooked up with my wireless service I have verzion wireless.
Nov 29, 2010 | Sharper Image Literati Reader 16375680042...
KOBO, INC Kobo Glo Logo
19 people viewed this question
Top KOBO, INC Tablets & eReaders Experts
Are you a KOBO, INC Tablet and eReader Expert? Answer questions, earn points and help others
