How to unlock airtel digital tv sd channel set top box
  • 3,320 Answers
SOURCE: TV not finding Digital Channels from Cable Box
We have Comcast and we plugged the cable straight into our Bravia, searched for Digital Channels and it found 131. We actually get all the HD channels that we had using the box, plus a few more. It's worth a try.
Posted on Aug 24, 2008
johncaman
  • 201 Answers
SOURCE: HDTV and cable box; no volume on channels higher than 99
Can you tell me, is the set top box connected directly to the tv? (i.e. not to a surround sound receiver or anything)
Posted on Mar 13, 2009
  • 814 Answers
SOURCE: Does my Insignia come digital cable ready or do I need a convertor box?
Yes you do need a digital converter box to get the digital signals converted for the analog television. The television is not set up for digital signal reception. For more information on this problem and technical help you can got to the Insignia website.http://www.insignia-products.com go to the customer support section and tell them the model number of you television and about the question of needing a digital converter box.You can also call them at their customer support telephone number 1-877-467-4289 and give them the same information. They will be able to explain the need for the converter box. I hope this information helps you with your problem.
Posted on Jun 03, 2009
Obertelli
  • 3006 Answers
SOURCE: Samsung LE32N7 - Analogue channels ok - Freeview
This is very common to a number of Samsung models built at the same time as yours and using the same in-built Freeview receiver.
There is no fix, the built in receiver is simply incompatible with the most recent updates to Freeview (as happened to many external boxes) and cannot be modified, the only puzzle is the length of time that your receiver kept going for. If your tv has a warranty still then you may wish to see if the fault is covered.
Without a warranty, all you can do is continue to use an external Freeview receiver. They're usually better quality anyway, and are easy to replace when they go wrong or become out of date.
Posted on Sep 17, 2010
  • 3 Answers
SOURCE: I just bought a teac
I find that with my HDB849 I have to be very carefull with the positioning of the aerial/rabbit ears to get all the channels to (ABC, 7, 9, 10, SBS and their sub cahnnels) to recieve them at all. Also once you get all the channels it is prone to digitization or pixilation at times due to bad weather/very overcast days.
Try the Teac.com.au for a firmware upgrade as this also solved not being able to view avis & images, listen to mp3's etc.
Overall the majority of reviews say the HDB849 is to be avoided.
Once set up correctly through trial and error and an absolute shitload of patience and re-tuning it seems to operate fine. Just pray you do not get a power outage or you have to start all over again.
Last point, try the teac 1300 number in Australia (or relevent country) and harras them for info whilst trying to stay calm and nice with the unlucky "tech support" person
Posted on Apr 17, 2011
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
Will the Panasonic DMR-E30 DVD Recorder replace my STB to receive the digital free to air stations on my tv?
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
Oct 06, 2011 | Panasonic DMR-E30 DVD Recorder
My problem is I have a dvd player DMR-ES 15 I live in australia is it possible to tune in the new tv stations example seven 2
It is not possible to tune in 7two, channel 11, GO! or similar digital channels with this model DVD recorder, as its tuner would most likely be analogue only. You would either need to upgrade to a model with a digital tuner built in, or purchase an external set top box, capable of SD and HD digital reception, and connect its AV outputs to the respective inputs of the recorder, in order to record the channels you want.
However, being in OZ, those digital channels are available as free to air - all you would need is the appropriate receiver to enjoy them. I recommend a set top box which offers HD as well as SD.
May 05, 2011 | Panasonic DMRES15 DVD Recorder
Now that we are on digital will the SD-37VB dvd vcr recorder work or do I have to alter a setting to make this happen
If the unit has a built in analogue tuner, the unit itself will still operate as normal, but without the built in analogue channels - to record a TV show, you would need to connect an external set top box to it (SD or HD - or both).
In other words, apart from a separate set top box, if required, there should be no need to change any of the unit's settings if it works as is. I do not believe this model has a built-in digital (DVB) tuner.
Apr 13, 2011 | Toshiba SD37VB DVD Player / VCR Combo
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
HOw do I retune old TV set(not digital)with a digital set set top box for digital channels
connect the box to your tv then connect a digital tv antenna to the converter box, scan for channels and then your set.
Jul 13, 2009 | Ectaco EAL400T (English / Albanian)...
How to operate 2 tv using one set top box with two differt remote contr
coax out on ctv box to coax splitter. coax to each tv from splitter. u will have the same channel on both tv's...otherwise pay for another cable box.
Jan 20, 2009 | Computers & Internet
Televison & Video Logo
186 people viewed this question
Top Televison & Video Experts
