Question about Amana ACS7270AS Electric Kitchen Range
I have an amana range Easy Touch Control 700. I am trying to replace oven bulb. Cover won't come off. Manual says 'slide wire retainer off cover' and the bulb cover will fall off. There is no wire retainer and although I can twist the bulb cover in both directions a bit, it simply won't come off!
aborcass
  • 2651 Answers
SOURCE: Amana gas range
the only f5 code listed for the amana range states faulty erc(electronic range control) solution replace control
Posted on Feb 26, 2008
  • 323 Answers
SOURCE: bad electronic contral panel on Amana gas range
On the Amana: Several Ebay stores carry panels like this. Problem is, once you open electronics they usually are hard to send back.
The stove is ten years old. You'll likely spend more than it is worth finding the right part and repairing it. It might be a good time to consider buying a new stove and selling this one for parts or scrap.
Posted on May 11, 2009
  • 58 Answers
SOURCE: My Amana gas range's oven door will not stay shut.
they're not too bad, you may need to take apart part of the door to remove the hinges, just remember where everything goes as you take it apart. bring the door to the first stop, then bring the hinge pin locks into place to secure the door hinge lock, then remove door, or just slide the door up. then replace the hinges as needed.
Posted on Jul 09, 2009
  • 80 Answers
SOURCE: Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Posted on Oct 03, 2009
jsrock516
  • 5911 Answers
SOURCE: how to replace oven igniter on amana ACS3350AS gas
The following link explains step-by-step how to replace an igniter in a gas range:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The replacement process is pretty standard with nearly all gas ranges. You can go to appliancepartspros.com for reference drawings to assist you as well. The oven burner assemblies are listed under the "Cavity" section.
If you have not purchased an igniter yet, the part number is AP4041245. If the connector plug does not match, there should be instructions that direct you to splice the wires using ceramic wire lugs. DO NOT use standard wire lugs. They will melt due to the high heat in the oven. The wires and connectors on these oven igniters are heat resistant. If ceramic lugs are not included with the igniter, you may have to purchase them separately. The part number is AP3440631.
This is a fairly simple repair, but if you have questions, please let me know. I hope this helps you.
Posted on Nov 15, 2009
Have a c970-440793 range. Need to replace the oven lamp light. I have the part in from Sears but there are no instructions.
Just slide the wire off of the glass lamp housing cover. It should just pop-off to the side. Then carefully remove the glass cover so as not to break it. Next, just remove the light bulb by unscrewing it counter-clockwise.
Screw in the new bulb (any small 40-watt appliance bulb will work,) hold the glass cove in place, then slide the wire back over the glass cover. The wire should be centered over the middle of the glass, towards you.
Sep 28, 2015 | In Microwave Ovens
How do i change the oven bulb in jer8885qas
I hope this may help you if it doesnt have visible screwss etc.
Sometimes the glass lenses are held in place by clips behind them which are not visible.
I am not familiar with your machine but I suspect the lens in thick glass and is slightly 'proud' of the oven side.
You have to have faith that it wont break it, but you have to CAREFULLY lever the lens out of its fitting using something like a blunt screwdriver. Once you get one side started, you will get the idea. The bulb is right behind it.
Sep 15, 2014 | Jenn-Air JER8885QA Electric Kitchen Range
Replace oven light mgs5875bds
DISCONNECT THE POWER TO THE OVEN -----1 - Hold bulb cover in place and slide the wire retainer off of the cover ----- 2 - Remove the light bulb cover and the light bulb ----- 3 - Replace with a 40 watt appliance light bulb ----- 4 - Replace light bulb cover and wire retainer ----- 5 - Reconnect the power to the oven and set the clock
Jan 10, 2012 | Maytag MGS5875BDS Stainless Steel Gas...
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
Change the lightbulb
take the outer case off light will be accessible for you to change it
Dec 08, 2009 | Microwave Ovens
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
How do I change the light bulb in the amana range
You change from inside of oven. Bulb will be located under glass bulb cover. Push clip to side, remove glass cover, then unscrew bulb.
Jun 16, 2009 | Amana ACF3325 Gas Kitchen Range
Oven light bulb
It just turns counterclockwise to come off. Sometimes it is very hard to turn them. If you have a strap wrench you could try that.
Nov 04, 2007 | GE Spectra JGBP35 Gas Kitchen Range
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Oven light
There's a sprung steel retainer clip holding the cover in place. Use a small screwdriver to pry it downward, the clip will release and the cover can be pulled straight off.
Aug 11, 2007 | Maytag MER5770 Electric Kitchen Range
Amana ACS7270AS Electric Kitchen Range Logo
64 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
