Question about Pioneer VSX-D411 Receiver
Surrond works a@b doesnt speakers
What capacitor or resistor could it be
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
There is no way to know until it is opened and inspected by a qualified tech. Sorry.
Posted on Apr 24, 2014
Only surrond works 0n stero reiever front a and b doesnt
Verify the main speakers are not blown or cables damaged or disconnected. If you have an ohmmeter, set it to ohms and measure across the speakers with no cables connected. You should see 3-9 ohms. Anything higher will indicate problems in the speaker(S). Get them reconed or replace defective speakers.
If the speakers test ok, remove the cables from the amp and speakers. Test your speaker cables by shorting both wires together on one end of the first cable. Connect the ohmmeter, set to ohms, to each wire on the opposite end. You should see near 0 or maybe 1 ohm. If not, the cable is open. Do the same with the other cable.
If these tests all pass, you have a more serious problem in the amp. You will have to take it to a reputable shop. Good luck!
Apr 21, 2014 | Pioneer VSX-D411 Receiver
Fuses on board blow after a minute or so after power up
Most likely the wire for the speakers, if you have them wired for a specified ohm that the amp doesnt support will cause the issue, as well as bad ground, cross connecting wires. I would start by removing all wires and connections, ensure they are clean and speakers are wired properly.
Nov 19, 2007 | QSC MX1500A 2-Channel Amplifier
Sony ta av431 Stereo Amp Front speaker do not
Have you check your sound configuration at front panel?
Oct 09, 2013 | Audio Players & Recorders
My AVR 130 front left and right speakers don't work anymore, Center, and the two surrond speakers works well, so I checked my connections and evrything seems to be OK, so now I am turning to all of you...
please check 3 pin white cement resistors in front left and front right channels has sound wave or sound. mostly, this model has cool soldering after this resistor to output jack by PCB thin board.
Mar 14, 2011 | Harman Kardon AVR 130 Receiver
Not all the speakers working
Open your audio control panel and set it to 5.1 surrond sound. Not all speakers will work unless a dolby surrond sound signal is being sent out. There will be a pseudo surrond setting which will emulate the 5.1 for you in the audio control panel
Mar 03, 2011 | Logitech X-530 Computer Speakers
I have surrond sound speakers thats loud but wend
I had an issue like that with one of my dell desktops too. The speakers were very quiet. I turned up the volume on the speakers, turned up the volume in windows. Unisntalled and Reinstalled audio drivers, I eventually assumed that the speakers were just junk. After buying a soundcard (I was originally using onboard sound), I discovered that the speakers were much louder through the soundcard than through the onboard audio.
Feb 28, 2011 | Dell Computers & Internet
Want to use Panasonic SA-HT740 for TV sound
Get the TV audio from the Dish box directly to the receiver.
Feb 16, 2010 | Audio Players & Recorders
I have a Dell 5.1 surround system that I bought for my computer. It has three cables, yellow, black, green, that connect to make it a single jack for the computer. I would like to hook up this system to...
well you can connect white and red to green connector(Front Speakers) the yellow connector is subwoofer speaker and the Black connector is for Rear Speakers) is not connected. The Tv dont have any Surrond decoder so to have full surrond needs surrond decoder
Jan 08, 2010 | Audio Players & Recorders
Digital display doesnt work is just off, while a blue bulb remains on, although the car is off
It is possible that the cap was installed too close to a sub and has simply broken because of vibration energy.
May 02, 2009 | Car Audio & Video
Pioneer VSX-D411 Receiver Logo
37 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
