Question about Linear Corporation Linear ACT-31 ACP00879 Mini Key Ring Remote Control - LD033 LD050 LS050 Compatible
Gate Key Fob
I need to order a new gate key fob. Model # ACP0879. Can you tell me how much that would be?
Rear lift gate on 2011 Yukon only works with key fob. Friend mistakenly pushed down manually instead of pushing close button on rear lift gate . How can we fix it?
When the gate was used manually the inside button was deactivated. Look in owners manual or contact dealer to see how to activate switch.
Jun 09, 2017 | Cars & Trucks
I have a 2003 trailblazer and i bought a fob and it does not work after programing Everything thing works on my truck but the fob. Any ideas?
How was it programmed ? Was a scan tool used ?
Program All Key Fobs
To complete this programming operation, all keyless entry transmitters associated with the vehicle must be available for programming. Once placed into program mode, all previously programmed transmitters will be erased from memory upon the receipt of the programming signal from the first transmitter.
  1. Close the lift gate.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program All Key Fobs.
  3. Follow the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
  4. As each transmitter is successfully programmed, the scan tool will show how many transmitters have been placed into memory.
  5. When all transmitters are programmed, exit the program mode by selecting "Stop" on the scan tool. The vehicle will not respond to the transmitters until the program mode is exited.
  6. Operate the transmitter functions in order to verify correct system operation.
Program Individual Key Fob
If there are less than four keyless entry transmitters programmed to the vehicle, an individual fob transmitter can be added. This method will not erase previously programmed transmitters from memory.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program Individual Key Fob.
  3. Select "Program additional Key Fob" on the scan tool.
  4. Follow the scan tool on screen instructions in order to program the transmitter.
  5. Operate the transmitter functions in order to verify correct system operation.
Apr 08, 2016 | Cars & Trucks
Can I unlock lift gate without a key on 2006 Isuzu ascender
Sarah, I believe you have to use key or key fob. to open/unlock lift gate.
Mar 03, 2016 | Isuzu Cars & Trucks
How to deactivate the security alarm without a key
if all key cyl disarm switch are bad , You would need to program a key fob to disarm the system....or repair one of the three disarm switchs in drivers door,or pass door or lift gate key cyl....good luck
Sep 02, 2009 | 1995 Jeep Grand Cherokee
Lift gate does not lock with key fob or with manual switch on the door.
sounds like you have a bad lock motor in the lift gate replace lock and check with fob
Aug 23, 2009 | 2004 Jeep Grand Cherokee
Tailgate lock assist will not work
my v70 vovlo estate(2000) tailgate wont open.checked fuses ok.no sound from mechansim when key fob depressed as the others do.Cant get into the back panel or open door at all.can you help with a suggestion?
Aug 05, 2008 | BMW 525 Cars & Trucks
Linear Corporation Linear ACT-31 ACP00879 Mini Key Ring Remote Control - LD033 LD050 LS050 Compatible Logo
115 people viewed this question
Top Linear Corporation Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Linear Corporation Home Fencing Expert? Answer questions, earn points and help others
