Question about Utilitech 3/4-HP 15 GPM Shallow Well Jet Pump 3/4-JET
Low water pressure how do i increase the pressure
    Genius:
  • 1,114 Answers
The water pressure is adjusted with the pressure switch, which turns the pump on and off. The pressure switch is typically set for a cut-in and cut-out pressure of 20-40 psi, or 30-50 psi. Usually there are adjustment directions on the inside of the switch cover. But, there are several other factors that may affect the house pressure. If there is a pressure tank that is pre-charged, the tank pressure may need to be reset, or the tank bladder may be ruptured. Have the entire system checked out.
Posted on Apr 21, 2014
How do I increase the pressure on my Flotec FP711OT-08. It is low 40s psi, can I move it up to 50 psi or high 50 psi? Water pressure throughout the house is low.
There may be a pressure setting on your outfit but My feeling is -- your problem will be low pressure on your water line. Most pressure settings is to keep from having too much pressure on what your running. For instance our city water pressure is 70 lbs but in order to keep my furnace boiler system at 16 lbs I have to install a pressure reducer.
Nov 23, 2014 | Pentair Flotec Fp7110t-08 Water Tank...
Tip
We just moved into a new home to us. The code came on with the first load. Our...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F20” error code.
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please refer to my profile and use the “Ask Me” feature if you require additional assistance.
on Nov 19, 2009 | Kenmore Elite 45986 Front Load Washer
Why does the pressure rise to over 3bar when the central heating is in operation ?
3 Bar = 43.5 PSI When you heat water it always expands increasing pressure.
In a closed vessel volume can increase by 2-3%. Either expansion tanks allow for this and PSI is maintain or without an expansion outlet the PSI will increase in proportion to heat supplied.
Is this a low temp hydronic boiler operating at or <140F, a hi temp hydronic boiler @ >180F or steam boiler?
Oct 18, 2014 | Water Heaters
Rheem 22v50f1
Backflow preventer is not part of water heater:
http://waterheatertimer.org/images/Watts-water-heater-parts.jpg
Water heater might have heat trap nipples that get clogged... but other issues have to be eliminated:
http://waterheatertimer.org/Low-hot-water-pressure.html
Gene h
Mar 27, 2014 | Water Heaters
Water pressure low on BAXi Combi 80e boiler
open bottom tap first then open top tap when water is to the leval you want turn off top tap then bottom tap.
Feb 03, 2013 | Heating & Cooling
I have low water pressure throughout the house. I
Depends on style of your pressure tank. Some allow you to adjust the discharge pressure.
Jun 29, 2010 | Plumbing
Would like to increase water pressure
You will need the expertise of a Plumber, this is beyond the scope of this forum.
Jan 26, 2010 | American Standard 2000.502.002 Ceramix...
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Utilitech 3/4-HP 15 GPM Shallow Well Jet Pump 3/4-JET Logo
429 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
