Question about Photography
Digital Photo Frame 8FF3WMI
Whenever I turn device on the following error message appears on the screen:"Failed to load executable file".
  • levtch Apr 21, 2014
    Accidentally the problem was classified under the category of "MP3 & Digital Media Players " instead of the "Digital Photo Frames" or similar
Inky
  • 691 Answers
SOURCE: DEVICE HAS'' READ ACCESS ERROR-CANNOT READ FROM HARD DISK''
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. If not you could try formatting it using a DOS prompt.
Posted on Jul 26, 2007
SOURCE: Trutech 7 Digital Photo Frame.
Try a new unformatted SD card (now they are around $10/1GB).
Posted on Jan 12, 2008
SOURCE: Problems with LG MP3 Player (due to a mistake in the operation of the device)
I too have had the "Device Manager code 9001 see manual" message come up on my LG unit, after having upgraded the firmware. All my music and photos disappeared and the unit would lock up if I tried to record anything.
I decided to format the device (from the General Settings) and the error message doesn't come up anymore. All my stuff was gone so there was nothing left to lose. It seems to be working now. I hope this helps you guys too.
Posted on Feb 05, 2008
SOURCE: Can't transfer data files
I called Sansa and I was instructed to format my player. The steps were as follows:
1)Connect player to computer
2)Go to my computer and right click on your player
3) Click format on the menu
This will start the formatting of the player. After this I was fine. This is the 2nd time I have had to do this in a year and all I put on this player are books.
******Please Note**** This process will erase any files you have on your mp3 player.
Posted on May 15, 2008
  • 148 Answers
SOURCE: I've got a LOGIK PF-A850WD
Please make sure that the photo files are in the root directory of the memory photoframe (ie, not within a folder).  That they are in a readable file format (.jpg) Check to see that the frame is reading from the internal memory and not the card slot.
Posted on Dec 12, 2008
Philips Photo Frame Failed to load executable file
Download the last Firmware-File from Philips and extract it. In the extracted folder is a file called execute.bin. This file must be moved over the Micro-USB-cable to the internal root folder. After a restart the photo frame should be automatically install the last firmware.
Dec 02, 2012 | Philips PhotoFrame -10 Digital Picture...
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
Whenever i take a picture and press to review it says file error
Hello!!
Try formatting ur memory card once and reload it ...
Apr 20, 2009 | Samsung Digimax S630 Digital Camera
Brookstone my life pocket album error
I had the same problem. I lwas able to load more pictures because I bypassed the function. It is easy. Just open the resized picture file on your computer, then, copy (control c) the pictures you want, and then open the photo album device through "my computer" and paste into the appropriate album. My digital photo album was listed as F Drive in my computer.
Feb 06, 2009 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Card read error on the digital picture frame - brand new. I bought this 7" digital photo frame from argos and I insert the SD card whilst the device is turned off, when I turn it on the message reads...
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Dec 12, 2008 | PANDIGITAL 7" Digital Photo Frame With...
I can't load photos onto my digital photo frame
The  A701 is  a bit cranky.  I've found that it prefers  USB  flash sticks of upto  2GB. It likes the flash stick formatting  before use.  And it prefers  jpg files  added  to the root directory of the flash stick -  so  no images in folders. Finally but probably least important, it's not much point uploading  2MB  jpgs as  the screen  is pretty much  72DPI  smaller size JPGS  lead to a faster loading. ( try  around 900x 600 dpi )
Nov 17, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Photography Logo
63 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
