Hi. I just bought a new Onkyo TX-SR313 AV Receiver. When I power on. it gave tick tick tick sound continuously every 3sec. No display at all. Had try to contact dealer but in vain. Thanks
    Problem Solver:
  • 17 Answers
Sounds like the output transistors are shorted. The relays are being tripped (tick tick sound) due to a major short. Need to get it to a technician familiar with receivers.
Posted on Apr 21, 2014
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
SOURCE: Onkyo receiver audio problem
I have Found two problem which cause NO AUDIO 27-07-08
jaiki39@yahoo.com
  1. 1.Failed connection between top &bottom of circuit board NCDG-6575 (Dolby --DTS) processing board.
Near & under IC Q710
2.Failed componet IC Q710 part # LC372100PT
IF you disconnet CKT board NCDG-6575
you will get audio on speaker B left & right CH only
SOLUTION have CKT board NCDG-6575 Repaired or REPLACED
Posted on Jul 28, 2008
SOURCE: onkyo TX-SR502 AV receiver
L7002
Posted on Dec 08, 2008
  • 17 Answers
SOURCE: My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
Posted on Mar 09, 2009
SOURCE: Onkyo AV Receiver TX-SR 805 no display on the receiver
Finally one of us found the solution - thanks to cambrian
Please follow the link
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=579
BTW: My knowledge of electronics is very limited, but nevertheless I could fix the problem. I hope you can do it too.
Posted on Mar 12, 2009
Fix onkyo ts-sr313 turn on problem
If the relay clicks on and then off straight away then it might have detected an overload condition and so shuts down. Overloads can be caused by faulty speakers or wiring. But if the damage is done already then one of the main power amp transistors or other devices could be short circuited.
Oct 16, 2014 | Onkyo TX-SR313 Home Theater Receiver - 5.1...
When receiver is powered on it is in mute how do I correct
out of external speakers refresh tv seting or component receiver setings audio setings refresh
Aug 30, 2014 | Onkyo TX-SR313 Home Theater Receiver - 5.1...
SERVICE MANUAL onkyo-tx-sr313
i need a manual service for onkyo tx-sr313
May 01, 2014 | Onkyo Tx-sr313 Txsr313
How to install/wire an RCA jack in Sony SA-WSIS10 Powered Subwoofer?
This link will allow you to download the manual for this system ... from there you may be able to figure out the solution or take it to an electronics expert for further advice.
Jul 24, 2013 | Sony Sa-wsis10 Sawsis10 Sub Woofer For...
Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Apr 26, 2010 | Onkyo TX-DS777
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Sep 06, 2017 | Onkyo TX-SV727 Receiver
52 people viewed this question
 Grubhead
Grubhead
