Question about Sony Cyber-Shot DSC-P32 Digital Camera
Camera won't stay on
Same problem, tried several types of batteries and the chargeables all were charged for at least two to three days.
    Brigadier General:
  • 4,090 Answers
Check that the battery terminals are actually tight connection
Posted on Jun 20, 2009
How do you recharge the battery casio m850
if it doesn't have a jack for a charger or a charger stand to sit it in then it will not be re-chargeable as such
you will have to remove the battery and check if it is an alkaline battery ( not re-chargeable ) or a rechargeable battery in which case you will need a battery charger for that type of battery
If that is the case get spares and have a fully charged one on hand to just swap over while the other is charging
Sep 13, 2015 | Casio Cameras
My battery comes dead really quick is there a way to boost it?
check the mhr on the batteries you use
they should be re-chargeable batteries as alkaline batteries do not have what it takes and run down very quickly
the re-chargeable battery should be around the 2000 mhr rating
Mar 30, 2015 | FUJIFILM Cameras
I have had my i phone for three days but will not charge beyond 50..percent...help
If the re-chargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 14, 2012 | Apple iPhone 5
My camera won't turn on...it is brand new
Brand new as in you just opened it out of the box? If thats the case you have to charge the re-chargeable battery first, then put it in the camera and it should work fine. Try giving the battery a charge first if you haven't already.
May 21, 2011 | Polaroid i1237 Digital Camera
When I put my battery back into my camera after charging it. The camera will still not turn on. Why ?
Check the position of the batteries. Some camera require the batteries to put in (+)(+) positive-positive position if we see from above. Some other require the batteries to put in (+)(-) or (-)(+) or (-)(-).
Make sure you have put in the batteries in the right place.
Sometimes, unchargeable batteries will stay longer than chargeable batteries, You can try to insert that kind of batteries.
If useful, RATE please.
Jan 18, 2011 | Casio Exilim EX-Z77 Digital Camera
NO PICTURES
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00614986&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=437165Solution two: Use the right battery What AA battery should I use for best performance? The following table summarizes how AA batteries perform in different types of use. Type of Use Alkaline NiCd Ni-MH Oxyride Photo Lithium Most economical when taking more than 30 pictures per month Poor Good Good Poor Fair Most economical when taking less than 30 pictures per month Fair Fair Fair Fair Good Heavy use of flash, frequent pictures Poor Good Good Fair Good Heavy use of video Poor Good Good Fair Good Heavy use of Live View Poor Good Good Fair Good Overall battery life Poor Fair Fair Fair Good Low temperature/winter use Poor Good Fair Poor Good Infrequent use (without dock) Fair Fair Fair Fair Good Infrequent use (with dock) Fair Good Good Fair Good Recharge batteries No Yes Yes No No Solution three: Make sure that your batteries are completely charged Follow the steps below for your battery type: Ni-MH rechargeable batteries Ni-MH batteries lose charge, or self-discharge, at a rate of one to two percent per day, whether they are installed in the camera or not. This means that if a battery is fully charged, after several weeks, the battery will be low or dead even if it was not installed in the camera or if it was installed in the camera but no pictures were taken. Ni-MH batteries are best for those who use the camera frequently and recharge often. The amount of charge that Ni-MH batteries can hold gradually decreases because of usage, aging, and lack of maintenance. To maintain your batteries at maximum capacity, "condition" them when they are new or have not been used for over a month. Follow these steps to maintain (condition) your batteries:
  1. Completely discharge the batteries by using the camera normally until it will not operate.
  2. Recharge the batteries.
  3. Do this three or four times.
NiCd rechargeable batteries Nickel-cadmium (NiCd) batteries lose charge or self-discharge at a rate of one percent per day. Store NiCd batteries in a cold place such as the refrigerator or freezer to minimize the loss. To store in a cold place, place the batteries in a tightly sealed container to keep the moisture out. Before using them, warm the batteries to room temperature. The amount of charge that Ni-Cd batteries can hold gradually decreases because of usage, aging, and lack of maintenance. To maintain your batteries at maximum capacity, "condition" them when they are new or have not been used for over a month. Follow these steps to maintain (condition) your batteries:
Alkaline, Photo Lithium, and Oxyride non-rechargeable batteries Make sure that the batteries are new and have not been used for anything else. . Solution seven: Try a new set of batteries If you have tried all the solutions described above but your batteries still do not last very long, try a new set of batteries. If the old batteries are damaged, a fresh set of batteries will solve the problem. Batteries can be damaged in the following ways:
  • NiCd and Ni-MH batteries can be damaged by over-charging. After a battery has been recharged, do not try to add additional charge to the battery by sending it through another recharge cycle before using it.
  • Batteries can be damaged by dropping or sudden impacts. Even if there is no apparent external damage, the rechargeable battery could later develop an internal short or leak while in the camera and cause damage.
  • If batteries have become wet, they may short out and will not work properly.
Jul 17, 2010 | HP Photosmart M417 Digital Camera
Camera rejecting new batters/not taking pictures
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 28, 2009 | Samsung Digimax S600 Digital Camera
Camera shows battery exhausted with new batteries.
You should be using Nickel metal Hydride batteries (NiMH). Do not use Nickel Cadmuim(NiCd), Zinc carbon or alkaline.
Mar 12, 2009 | Nikon Coolpix L1 Digital Camera
Change batteries message pops up with new batteries
Chargeable batteries usually last for a year or two. Alkaline batteries should only be expected to last for around a dozen shots (as such, NEVER rely on alkaline batteries). Recommend buying another set of NiMH rechargeables. Make sure you get 2500 mah or better power rating (look on the package).
Jun 23, 2008 | Canon PowerShot A85 Digital Camera
Everytime i turn on the camera it goes right back out
ok honestly our camara type is a ***** they need the perfect batteries and dosent take just any brand chargeable batteries are a waste because our camera will reject them no matter what try a diffrent brand
May 25, 2008 | Polaroid PhotoMax PDC 4055 Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
115 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
