When tv is turned on it has 4 horizontan bars on screen and evenly space. after about 15 minutes screen is normal
SOURCE: Picture won't come in clear until TV "warms up" for 15 minutes or more
Change the capacitors first per the instructions in the link below. Symptoms could be anything from high-pitched hum to no picture at all. On these defective models, I would start at the caps and work back. It won't hurt to replace them anyway.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
SOURCE: 3 horizontal lines during start ups(turning on)
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
SOURCE: Lines across screen breaking picture into 4 sections
Based on reported problems with Samsung LCD tvs, It is probably one of three problems:
Separation of layers of the LCD panel;
A defective LVDS cable connection;
A defective T-Con circuit board.
If light hand pressure on the affected area on the LCD panel changes the problem, its the defective panel. If not, manipulating the LVDS cable will reveal the cable defect. If not, coolant spray applied to the T-Con circuit board should reveal if it is defective by temporarily alleviating the problem. Dont remove the back cover if you dont know how to protect yourself from electrical shock hazards. There can be more than 1000 volts in the backlight inverter area.
Jerry S
SOURCE: I have a 46 inch
This tv is not repairable only can be replaced the Plasma screen itself.Not woth it,replacing the plasma screen,will cost the same as a new tv.This problems,u discribing is the Plasma screen itself sure comming to used and ages.Not any electronic boards componnent.Because the floorscents Plasma gas u seeing on the screen itself forming and lighting up the Plasma screen itself.
