Question about Humminbird 595c GPS Receiver
Interference I've had this unit for a few years with no problems but this year when I went to use it I have alot of interference on the screen while running my electric motor. If I turn the motor off the fish finder works fine. Any suggestions?
2 Suggested Answers
  • 67 Answers
SOURCE: I have a hummingbird matrix 67 gps chartplotter
Hummingbird will refurbish that one for around 150US dollars, better then 500+ for a new one. If the screen is subjected to direct sunlight and heats up it can go out. This is why they discontinued the 67 model and replaced it with the 767.
Posted on Sep 22, 2009
I have a Airline 77 purchased about 5 years ago. Recently in all club venues the sound man is experiencing a lot of hiss and I seem to get alot of interference periodically. Wrote to Samson and the
Make sure the frequency of your system is still usable. The FCC has changed the spectrum used by wireless mic's and you may not be able to control intereference form other users.
Nov 19, 2014 | Samson AirLine 77 Wind Instrument System
Cordless phone on same bandwidth as wireless belkin router
Yes, you can change the bandwidth of your router if you are facing the interference problem. You can change the bandwidth and check whether both are still in the interference or not; continue to change BW, till its not in interference.
Apr 22, 2013 | Computers & Internet
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
About 10 days ago our remotes stopped working, as well as the homelink in each car. used the learn button to reset the remotes, but now they only work within about a foot of the opener. keypad outside...
I find it weird also. Check this out.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
System is about three years old Liftmaster Professional Formula 1 Recently developed a problem where we are unable to open the door using the keypad or the remotes. The keypad (new) does not work...
If it is the receiver and it sounds like it is they run about 2/3 the cost of a new unit. That is if you install it yourself.
The first step is replacing the battery in your remote.
Dec 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have lowrance 337 c gps combo, I have a lund baron i/o aluminun boat. When the boat is running i get alot of interference on the screen. I tried running the power cord for the graph direct to the...
You can use a thru-hull transducer but a transom mount transducer will always interference with all of that water and alot of air bubbles moving under it at high speeds.
Jul 16, 2009 | Boating
Uniden BC80XLT Radio Scanner distorted
It may very well be an interference problem. While the scanner may not have moved, there are many items around it that may be the source of interference. Think back to the time when the interference started. Did you install something new around that time frame? Perhaps a new computer, a new monitor, some new CFL light bulbs? Any of these items can cause interference. The other possibility is that the interference is coming from outside your home or office. While these sources may not be able to be corrected, you can do a few things to help reduce the effects of the intererence:
1. Move the scanner to a new location. Radio waves are tricky little things. You may be able to find a location where the interference is weaker, but your intended signal is still adequate.
2. Try moving the antenna. If using the rubber antenna that came with the scanner, try laying the scanner flat instead of upright.
The other thing you may want to do is check the frequency with another scanner. There is always the remote possibility that the problem is with the transmitter, and not with your scanner at all.
I hope this helps. Good luck!
Dec 27, 2008 | Uniden BC80XLT Handheld Scanner
Garage dr won't close because trolley interferes with rail joint
Run the unit with the door unhooked.
Work the door manually.
If the door works smoothly and easily up and down and the opener works normally when not connected to the door you probably have a bad gear kit.
Unplug the unit - take of the cover – if you find white shavings inside – these confirm the diagnosis. .
Get the gear AND sprocket kit.
It’s a good DIY project but you MUST VERY CAREFULLY Follow the instructions step by step.
HOPE THIS HELPS
Dec 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Matsui 42" plasma TV
hi everyone, well i,ve solved our problem. i had the same head bashing problem for months,tried everything.what you have to do is turn all display settings to 0 and then run tv for several hours like that,then slowly bring up brightness and colour only leave contrast at 0. i,ve tested this for a week now and bingo the light show is over at last,my god the relief.good luck everyone
Sep 03, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Humminbird 595c GPS Receiver Logo
18 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
