Question about Huffy Pro Thunder Boys 16-Inch BMX Bike
Huffy boys bike makes clicking noise - Huffy Pro Thunder Boys 16-Inch BMX Bike
    Scholar:
  • 102 Answers
Does it make the "clicking" noise when coasting, pedaling or both? If it is only when pedaling, check to make sure the cranks are not rubbing on a chain guard or hitting the frame, if not then the chain is probably too tight and it is the gear cog teeth meshing with the tight chain. Loosen the rear axle nuts and slide the rear wheel forward slightly, this should take care of it. If the noise happens while coasting then one of the wheels could be rubbing on the frame intermittently, or the hub bearings could be too tight (also making it difficult for small legs to pedal) and the bearings are crushed and flattening making the "clicking" noise as they are being ground up.
Posted on Nov 02, 2015
2 Suggested Answers
  • 21 Answers
SOURCE: remove the pedals from a boys huffy bike
Bike pedals can be a little tricky, but most likely for that bike you will need a 9/16's wrench. There should be some flat surfaces inboard of the pedals between the crank arm (the long arm that you screw the pedals into). Now, here's the hard part - the R pedal is normally threaded, but the L pedal is reversed. The easiest way to remember which way to turn the wrench is to stand behind the rear wheel and you will always pull the wrench towards you to loosen. Depending on how long the pedals have been on, they might be pretty tough to get off. You could use some penetrating spray (like Liquid Wrench) and let that sit for awhile. Also, once you get the pedals off, remember to put a little grease on the threads so that next time they won't be so tough!.
Posted on May 14, 2010
Hi, I have a boys 20inch huffy bike we are struggling majorly to attach the front wheel can anyone help ?
Over the Internet, without knowing why you are having a problem, it's very difficult to help. It is certainly important that it be assembled properly before it is ridden. Try some of the videos in this Google search: install front bolt on wheel bicycle Google Search
Dec 24, 2016 | Huffy Cycling
My son has had his huffy axis less than 6 months the handle bars broke hoiw can i get it replaced
It is unclear what actually broke here (stem, handlebar itself, steerer tube?) Take it to a bike shop or do some web searching to find a solution that matches what you see. "how to ..."
Aug 31, 2011 | Huffy 20in Boys Axis Bike
Seat assembly came apart out of the box and I need direction on how to assemble the seat mount components
Please go to my tips and tricks page. There are links to huffy's website for on-line assembly instructions and detailed owners manuals. Good website.
Dec 15, 2010 | Huffy Pro Thunder Boys 16-Inch BMX Bike
Left peddel is stripped will not stay on
If it is the peddle that is threaded and not the crank then all you need to do is replace the peddle. Take the peddle off and look at the thread both on the peddle and inside the crank. Any bike shop can look at this for you and can order you in a set of new peddles or, if the crank is to blame you can order these easy enough online.
Jun 09, 2010 | Huffy Brazen 20 Boys' Freestyle BMX...
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
Remove the pedals from a boys huffy bike
May 11, 2010 | Huffy 16 in. Boys Diego Single Speed Bike....
Huffy Pro Thunder Boys 16-Inch BMX Bike Logo
605 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
