Question about Logitech QuickCam Messenger Web Camera
Quick cam shows my tv tuner channel and not my image
When i start the webcam up it picks up my tv tuner channel and show that instead of my image in front of it
  • 1 more comment
  • vega01 Jun 02, 2008
    Hello.
    Had the same problem. I've changed my cam source and it's ok now.
    Thanks Nichu
  • detlef peter Jun 06, 2008
    When switching on my quick cam I pick up tv from my tuner - no sound though
    Where do you change the source ?
  • 170 Answers
Hello igloo,i am nichu
ya this problem is common, although it is not a problem.what's hapenning is that your webcam's source or the channel is changed ,thats why whenever you switch on your webcam you see the tv in your webcam window .
hence to avoid this change the source of your webcam ,chose option other than the tv tuner i.e., the webcam one,which is in your webcam window it is there in your options tab,,,,,,,,,,,,,,,,,,,,,,,,,,,,,problem solved.
take care
bye and have a good day
Posted on Nov 06, 2007
My son bought this TV and had it hooked up to a cable connection with an HDMI cable and it worked fine. He gave the TV to me and I hooked it up to a basic cable connection with no cable box. It does not...
If your TV has an On-screen Menu you should be able to access your Tuner controls. Run your auto channel scan and you should pick up your "regular channels". You may be able to de-select the odd channels and show only the ones you want to use.
Oct 03, 2011 | Westinghouse LTV32W6HD 32 in. LCD...
I am using win7 so i open honestech tv tuner i get open webcam
Ibrahim Please State your Details properly first! and If you are facing problems with your TV Tuner card Card in Windows 7 Please use TV Expert Software instead of Honestech and First Disconnect your Webcam, install the TV Tuner Card drivers properly, install the TV Expert Software for you TV Tuner and Try to run the TV. I am also using Win 7, Philips TV Tuner installed with TV Expert Software and a web cam but no problem here.
May 07, 2011 | Computers & Internet
I bought the Frontech Diamond webcam and installed the CD and the message shows its successfully installed, as its requested i restarted my system. After i open my cam,, the light will ON but in the CAM...
check if your USB cable is properly plugged.
Also try connecting your webcam directly to your PC instead of through a USB hub
if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
Feb 13, 2011 | Cameras
We can't get any of the channels don't know where to start from menu area
Hello
You just do autotune to receive all channels. In this mode TV will tune through the entire channel band automatically, and finally will stop tuneing, and will show the first channel receved. You must be patient for these time. about two or three minutes, without disturbing is process. The tuning process follows.
Auto Tuner Setup
In Auto Tuner Setup, the TV automatically scans
t h rough all available channels, memorizing the active
ones and skipping over blank ones or channels with
weak signals. This means when you scan (using the
CH A N N E L +/- b u t t o n s ) you will receive only clear,
active channels
P ress the ME N U b u t t o n
Press UP or DOWN buttonTo AUTO TUNER SETUP
Press Right or Left button to operate
Press Vol+ or Vol (--) to choose CABLE or AIR
Press UP or DOWN button to move to START
Press Right or Left Button to start Auto Tuner Setup
Tv will show "NOW PROGAMMING" display.
Programming will take approximately 1 to 2 minutes.
After all it will show
PROGRAMMING OVER
Some cable systems experience interference from radio frequencies on cable Channel 95. You may delete this channel from
your scan by removing the "X" next to it on the Channel Summary screen.
Nov 29, 2010 | JVC AV-27120 27" TV
The tv is showing a double image and I cannot get the color right! Model number 50v500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to upgrade to the high definition cable box---but first try this. Hook the cable from the wall directly to the tv and autoprogram it. If Comcast is anything like charter they transmit the local Hd channels in a format that digital tuner will pick them up. Just channel up/down and check out the channels with -1 and -2's behind them. Depending on where you are----your local channels will usually show up wherever they normally do but with a -1 behind it.
EX: local Fox channel on 47---autoprogram and check 47-1
If this is enough HD for you then get a two way spitter and hook your box back up and keep using the RCA (composite) cables for the best it can produce.
hope this will help..
May 21, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Webcam show pick of cam with x instead of me
When you start windows live messenger - there is no programme using your webcam. I.e Instant capture or any specific programmes running your webcam are turned off?
In windows live messenger - Can you see your webcam listed to use for video calls?
May 22, 2009 | Microsoft LifeCam VX-3000 Web Camera
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
Logitech QuickCam Messenger Web Camera Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
