Question about Nokia N73 Cellular Phone
How to improve n73 signal length - Nokia N73 Cellular Phone
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
You cant do anything, it all has to do with the network you are with and the towers
Posted on Apr 24, 2014
Whats is Service Engine Code P1800 - VIAS Control Solenoid Valve Circuit Open
Here is the definition. Cost would depend on your area and the actual problem found after testing.
P1800 NISSAN Description When the engine is running at low or medium speed, the power valve is fully closed. Under this condition, the effective suction port length is equivalent to the total length of the intake manifold collector's suction port including the intake valve. This long suction port provides increased air intake which results in improved suction efficiency and higher torque generation.
The surge tank and one-way valve are provided. When engine is running at high speed, the Engine Control Module (ECM) sends the signal to the Variable Intake Air System (VIAS) control solenoid valve. This signal introduces the intake manifold vacuum into the power valve actuator and therefore opens the power valve to two suction passages together in the collector.
Under this condition, the effective port length is equivalent to the length of the suction port provided independently for each cylinder. This shortened port length results in enhanced engine output with reduced suction resistance under high speeds.
Read more: http://engine-codes.com/p1800_nissan.html#ixzz2JgphPIVM
Feb 01, 2013 | Cars & Trucks
Netgear wna1100 can't get it to get tronger signal
This is a simple, USB based network interface card (NIC). There's little to be changed as it is built with tiny surface mount devices that can not dissipate heat nearly as well standard through hole components can. Boosting voltages, etc will only shorten the life of the device.
Locating the NIC closer to the WiFi source will improve throughput of the device. If this is not possible, increasing the height or physically reorienting it may provide some gain. The easiest way to do this is to purchase a simple USB cable that will connect to the computer's USB poert and accept the WNA1100 on the other. These cables are often available at electronics and computer stores in 3, 6 and 12 or more foot lengths for under $20 (and significantly less online). I would not purchase or connect lengths greater than 15 feet, as this is the maximum length supported by the USB standard without some sort of active repeater built in to the receiving end. By placing the WNA1100 at the end of the cable, you are free to orient it in the best position to maximize capture of the WiFi signal, regardless of the position or location of the computer.
May 14, 2012 | NetGear WG Computers & Internet
Signal ic default setting in n73
I am sorry, but we specialize in headsets, not mobile phones, so we cannot answer the question you sent to us.
Dec 04, 2011 | Nokia N73 Cellular Phone
Processing speed of my nokia n73 is very slow
It seems that you have not formated your phone for a long time. Formatting the phone will improve the speed of your phone. To format follow the following steps:
1. Please take backup of your contacts and messages before formatting because these will be deleted during the formatting. Make sure your battery is fully charged.
2. Dial *#7370# and enter the security code ( default is 12345) when the phone asks for it.
Thats it. Phone will restart.
You will notice a great improvement in the speed of your phone.
Don't forget to rate me. Thanks for using FixYa.
Feb 02, 2011 | Nokia N73 Cellular Phone
My nokia n73 has sound problem. no heard calling or receiving sound. how to improve it?
Maybe it's the profile? Set it to normal mode it should be able to work.
May 03, 2010 | Nokia N73 Cellular Phone
Nokia N73 signal problems
network is dmaged go to mobile phone repaier place and fix it will cost 30 to $40
Apr 16, 2010 | Nokia N73 Music Edition Smartphone
Probelm with file transfer N73
Hi, Welcome to FixYa
The files transferd using Bluetooth to Nokia mobiles will be normally in the inbox. You have to manually move the files to your filesystem of the mobile so that you can use it.
We need your feedback for our improvement.
If you are helped with the post please select 'YES'
Jul 09, 2009 | Nokia N73 Cellular Phone
NAD 7130 FM stereo signal (on off again and again)
The contacts in the A B speaker selector switch had degraded on my NAD 7130 receiver. Distortion and signal loss would come and go. Contact cleaner and wriggling the swx knob became useless. Then, years ago I jumped the swx with small lengths of bare wire and tinned the whole thing with solder. Never had a problem since and it probably improved the receiver because it eliminated a component in the output stage that could (and did) introduce distortion.
Mar 16, 2009 | NAD 712
Cant install games on my Nokia N73
try to update your cellphone firmware that will solve the problem.
Nov 18, 2008 | Nokia N73 Cellular Phone
I have forgot my lock code of my n73 can u suggest me a solution
default LOCKCODEis -12345
if you already replace this with some other
you just try
all of the securite pin no"s you used usualy(normaly) if no improve ment you just UPGRADE your Mobile FRIM WARE UPDATION. BYTHE HELP OF ANY MOBILE PHONE PROFESSIONL.
fine now you get your
New default LOCKCODEis -12345
and your mobile start works .with
default LOCKCODEis -12345.
OK
Thanks for trying FIXYX.COM
Nov 17, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
