Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven door won't close on my spectra ge - GE Profile Spectra JGBP90 Gas Kitchen Range
    Champion:
  • 216 Answers
Oven clean door lock is blocking door from closing.
Posted on Apr 21, 2014
  • 18 Answers
SOURCE: GE Spectra Oven not working
its sounds like your board is shot. replace board
Posted on Feb 04, 2007
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
  • 833 Answers
SOURCE: GE Spectra JGBP85
Try this: turn off the circuit breaker to the oven. You are looking for a pair of breakers generally rated 40 amperes or more. Turn them off, wait a minute and turn them on. If that doesn't do it, then there may be a circuit board issue.
Posted on Dec 13, 2007
SOURCE: oven
Same here, my wife freaked cause Christmas turkey took 6hrs.
I read somewhere that its internal thermostat. GE should offer to look into this seemingly wide spread problem
Posted on Jan 01, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
I have a GE Spectra range/oven the oven will no come on and gives me a F4 error message, can you help?
Hi
F4 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
General electric spectra electric oven, door doesnt close complete. Heat from the oven comes out.
please,i need help!i have a problem about my GE spectra electric oven door is loocked i cannot open at all,what i can do?to be open?
Mar 29, 2011 | GE Spectra JBP78 Electric Kitchen Range
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Do you kep door closed when broiling
Hi, yes, your oven door should be closed , at all times whenever you're using it, otherwise your home will become oven, use oven thermostat to maintain temp, door should be closed, especially on broil. knob you turn, to light oven is also a thermostat. good luck.
Aug 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
New to this, so explain if door goes up to close or left or right to close?
Jul 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Trying to remove oven door
ge spectra elec., how to remove the oven door
Jan 30, 2009 | GE Spectra JBP78 Electric Kitchen Range
F2 error
an f2 code means the oven overheated.it could be a bad relay on the control board. also if you ran a self clean cycle and left the racks in the oven,i've heard it could cause problems with the oven sensor.
and no you shouldn't have to leave the oven door open when you cook.hope it helps
Nov 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
51 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
