Question about Vehicle Parts & Accessories
Radiaor leaking radiator
    Genius:
  • 1,114 Answers
Where is the leak? What vehicle, year, model, engine??? Usually leaks in a radiator are not repairable, or the cost for repair is more than a replacement radiator. If the leak is in the core, the aluminum part,or in the plastic tank, the radiator needs to be replaced.
Posted on Apr 21, 2014
91 Geo Prizm radiaor leaking/spraying coolant
It's probably the cap if that's where it's leaking from. They are inexpensive and easy to replace. DO NOT replace it while hot though.
Apr 17, 2014 | Geo Prizm Cars & Trucks
Radiaor is pushing water back out of reservior and over heating
Radiator must be rodded out at radiator shop.
Feb 08, 2013 | Water Heaters
1998 Toyota Camry 4 cyl.only blows warm air from heater when car is unning for say ten min. When I start driving the temp gage goes down to cold and blows cool air, no heat. I changed thermostat and...
Your radiator cooling fan will only come on when the engine temp has reached the point where it needs to have air forced through the radiator and thus bring engine heat back down to safe operating range. If your heater is not working check to make sure the fresh air vents aren't stuck open (are the controls stiff or not going all the way across?) check also that the heater shutoff valve lever which is usually situated on the firewall at the rear of the engine and can be found easily by tracing the hoses back from the thermostat housing aren't bent and/or seized up.
Apr 08, 2017 | 2000 Toyota Camry
Where is radiator drain plug on a 2006 buick lucerne
It's on the drivers side, Standing in front looking at the engine it is on the lower right corner, facing the engine/transmission.
Nov 12, 2012 | 2006 Buick LaCrosse
Running hot
Remove thermostat and test it by dipping it in cold water ib an open pot. Heat the water on the stove while observing the thermostat. It shold opel just before the water boils. If it does check the radiator itself for clogging. Also fluch the engine water galleries.
Sep 27, 2012 | 2000 Chrysler Town & Country
How do i replace the radiaor? on this 2005 Hyundai do i remove the intake cover, then the cooling fan, the the motor mount? what?
Below are instructions and a diagram for removing the radiator from your Santa Fe. There's nothing involving the motor mounts. Best of luck and please post back with any questions or just to rate the solution. Greg
  1. Drain the cooling system. Remove the radiator cap to speed draining.
  2. Remove the inlet hose from the radiator.
  3. Remove the transmission oil cooler lines from the retainer clip at the bottom of the cooling fan shroud.
  4. Remove the fan shroud clip from the condenser tubes.
  5. Remove the bolt that connects the fan shroud to the condenser hold down bracket.
  6. Remove the air deflectors from the top of the radiator.
  7. Remove the cooling fan shroud bolts.
  8. Remove the coolant reservoir hose from the radiator overflow neck.
  9. Remove the radiator upper support brackets and bolts that connect to the fan shroud.
  10. Disconnect the engine cooling fan motors electrical connectors.
  11. Remove the cooling fan motors electrical harness from the fan shroud clips.
  12. Remove the cooling fan shroud.
  13. Remove the outlet hose from the radiator.
  14. Disconnect the transaxle oil cooler pipes from the radiator.
  15. Tilt the top of the radiator rearward.
  16. Remove the condenser hold down bracket from the radiator.
  17. Lift the condenser from the mounting tabs on the radiator and position the condenser aside.
  18. Remove the radiator.
Aug 11, 2009 | 2005 Hyundai Santa Fe
95 VW Jetta is overheating
You'll have to remove the radiator (it isn't that hard) and take it to a Yellow Page listed radiator repair shop...Be prepared to spend $200, less if you're lucky...Don't forget to put water pump lube (NAPA #13 - looks like milk) in the radiator after replacing the fluid 50/50 mix
Jun 14, 2009 | 1996 Volkswagen Jetta
Car radiator problems subaru wrx 1995=6
cheak to see if y of th water pipes are leaking and check the radiaor, if all these are fine the unfortunately it could be the headgasket blown.
please rate this advice.
Dec 24, 2008 | 1996 Subaru Impreza
Removing tranny lines from radiaor
on some fords a special tool is required to remove the lines. but it is not expenzive
Dec 08, 2008 | 1997 Ford Windstar
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
