www.cargurus.com > Questions > Chrysler > Town & Country
CarGurusSep 29, 2008 - ckf2004 answered 4 years ago. I have a 96 chrysler town and countrylx and the engine died, turned over but wouldn't start, I researched and replace the flywheel .... My van sometimes won't start because it kills the battery.
CarGurusMy town & country 2004 wont start sometimes - My van start doing something really weird. it will ... Asked by TownCountryguy May 03, 2013 at 03:31 PM about the 2004 Chrysler Town & Country Base .... Sometimes you tap it & it won't work.
? 1:01
https://www.youtube.com/watch?v=mkEL2vlLZr0
Jun 26, 2014 - Uploaded by Philip Walker
We have the same issue currently...very randomly...with our 2008 Caravan at the moment. Wife just got ...
Check the heater cores. There are usually 2 in a T&C. Also check the pipes running to the rear heater core. I recently had to have mine repaired because they were leaking!
the thermostat is place between the engine block and the radiator either in a housing on the block or in the top radiator hose , follow this u-tube link for step by step guide , nice and easy Thermostat replacement on 2002 Town and Country
REMOVE DASH PANEL WITH PLASTIC PRY TOOL EAST ACCESS TO SWITCH, ON STEERING COLUMN COVER OFF BEHIND WHEEL AND EASY ACCESS 2 SMALL BOLTS, UNPLUG, REPLACE AND REASSEMBLE
the relay is located in the power distribution box under the hood the relay will be a square black or gray cube just pull out and make sure you rerplace it with the same type relay. refer to your owners manual for any questions regarding the fuses and relays
