Sharp lc32d12e flashing white light
2 Suggested Answers
SOURCE: MY tv will not come
I have asharp tv model number LC 32D12E serial number 012913930. The standby light keeps flashing and will notturn on.
Posted on Aug 06, 2011
Hi ai have a LC32D12E. The power light flashes but the tv seems unresponsive when ITry to turn on?.
hi this power supply fault, could be capacitors or a mainboard fault thanks
shaun
Mar 26, 2017 | Televison & Video
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
LC-60LE600U DUNTKF908WE04
Sounds like corrupted firmware. A firmware update is necessary. Contact the authorized service center for Sharp.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 08, 2016 | Sharp AQUOS LC-60LE600U 60" LED TV...
60" sharp aquos power indicator is flashing one short flash and one long flash and keeps repeating the sequence
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN [ - ] HOLD BUTTON.
3)Press Channel UP [ ^ ] HOLD BUTTON.
4)Press Power [ (') ] HOLD ALL three buttons until LED stops flashing and then release.
    ┬ĚThis will reset the TV in order to fix the problem.
    ┬ĚTHE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
    Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
    Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to LGTR61@YAHOO.ES. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
    Where can you buy the LED's - try searching Yahoo.com or Google.com for resellers.
    SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
    LONG STRIP (49 LED's)
    FRONT SIDE BACK SIDE RL 94v-0
    E329419
    1029
    LFa
    Sn-Ag-Cu
    Ps-1
    K4458TP
    4458ZZ
    0921FM
    104863
    ee03A
    SHORT STRIP (30 LED's)
    RL 94v-0
    E329419
    1025 LFa
    Sn-Ag-Cu
    Ps-1
    K4459TP
    4459ZZ
    0714FM
    302213
    Mm05A
Apr 10, 2013 | Sharp LC60LE810UN 60 in. LCD TV
How to reset LC60LE810UN
How to perform a cold hard rest on the Sharp LC-60LE810UN TV? It won't power on and just blinks.
Apr 14, 2012 | Sharp LC60LE810UN 60 in. LCD TV
60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Dec 04, 2011 | Sharp LC60LE810UN 60 in. LCD TV
MY tv will not come off standby its a Sharp LC32D12E
Mar 04, 2011 | Televison & Video
We have anew sharp lc32d12e lcd tv! We cant find the PS3 on there when we set it up! Is there a AV channel?
You have to have the tv "set" to the right input. note where you have hooked up the cables in the back (inputs should be numbered) you must select the coresponding input number on the input selection on the remote.
Jan 20, 2011 | Sharp Televison & Video
Sharp AL 1010
Hi, to reset drum light follow this sequence: press cancel, exposure, cancel, exposure. Display goes blank, enter 24, print, 07 print, cancel cancel. Cheers
Andy
Jan 25, 2008 | Sharp AL 1215 Black and White Copier
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
