Question about Lands Phones
Nec dt300 voicemail does not pick up just rings and rings
  • 201 Answers
SOURCE: VOICEMAIL
This is all programmed in the phone system settings. Your phone can be used on different Avaya phone systems (AT&T, Lucent is Avaya now) and you can also have different voice mail systems. They all program differently.
Sounds like your phone port is not programmed to use voice mail. You can have your phone port programmed to do many different things if nobody answers. Mostly you have the call transfered to another station after so many rings. That other station (extension) could be the operator, a calling group, a voice mail box, etc... Some systems allow you to change the number of rings on a per-phone basis, others only have one no-answer timer for all calls.
You can get all the manuals from www.avaya.com for free but you need to know which system and version you have first. Programming can get very complicated and you may find it easier to hire a local phone installation company that is familiar with your system to do the changes for you.
Posted on Jan 28, 2008
cnavarro
  • 2460 Answers
SOURCE: # of rings before voicemail picks up
Yes there is, but you have to know multiplication :-)
At the extension, from the intercom dial *713 and the 2-digit time in seconds. An internal ring cycle is about 6 seconds. I think the default time comes from the system and it may be 40 seconds.
Carl
Posted on Mar 23, 2009
consultel1
  • 860 Answers
SOURCE: The phone rings 3 times and goes to voicemail on
I don't think its a good idea to back the vms cover rings to 8. The furthest I'd go is maybe 6.
Changing the VMS cover rings on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#321"
the display should say VMS Cover Rings and ask for an extension number
enter the extension number you wish to change
The current ring data should be displayed
enter in new data (8 ring if you wish)
press feature "00" to logout
Posted on Dec 10, 2009
SOURCE: How do I change the extension name on the display
* Press SPEAKER key *Dial 700 Enter extension number Use keypad to enter name (up to 12 characters) (note: # = Accepts an entry (only required if two letters on the same key are needed - ex: TOM). Pressing ## = Space.) *Press HOLD *Press SPEAKER key
Posted on Jul 19, 2011
SOURCE: change the time on our NEC DT300 Series
What model of NEC phone system do you have? Go look in the phone or data room and look at the PBX. You might also be able to press Feature 3 to get some information which would be helpful to a tech. If it is an SV8100 try this:
To set the system Time:
1. Press
Speaker.
2. Dial
728.
3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM).
4. Dial two digits for the minutes (00~59).
5. Press
Speaker to hang up.
Posted on Oct 08, 2012
Need access to voicemail on NEC DT300 series, and reset password. Previous employee held this position & no code was left behind.
you may not be able to get to the VM. You may have to reset the system and start over if the PW is not avaialble. I cannot find a way to reset only the VM password and retain the VM. You may want to contact NEC directly in case they have a way that isnt in the manual. The manual seem to indicate you need to reset the entire system. NEC DT300 Series User Manual To Change Security Password
Apr 02, 2018 | NEC Lands Phones
Wanting to extend ring time - changed by itself - only ringing 5-6 times before going to message bank.
5-6 rings I think that is the best you can get
link to a manual for it
SV8100 DT310/DT330/DT710/DT730 User Guide - NEC Corporation ...
https://www.necam.com/Docs/?id=5601ae16-b7e2-4e8c-a769...
NEC-10645 UNIVERGE SV8300 DT300 DT700 USER GUIDE
au.nec.com/.../SV8300_Handset_Manual-ce03fb6c-32af-4991-9bd5-8ec.
Sep 09, 2016 | NEC Dtl-12d dt330 12-button Digital...
I have an NEC DT300 and would to extend the amount of rings before it goes to voicemenil
It might not be a viable option. However you should be able to try to make changes like this via the settings menu. Is the user manual any help?
May 06, 2015 | NEC Lands Phones
NEC DT300 has call light flashing red with no call on the line. How do I make it stop?
PUSH JUST THE BUTTON SPEAKER TWICE
IT MAKES THE HAND FREE CALL YOUR PHONE WAS FORGOTTEN ON FREE HANDS CALL
Oct 20, 2014 | NEC Univerge Dtl-12d-1 680002 Dt300 Refurb...
HOW DO I GET THE CF LIGHT OFF?
First, you've posted this is Nortel Phones, while your model is an NEC - you might have more luck posting in the NEC section.
When you do, it would help if you add more detail on which button (sp?) stays lit. If it's Call Forward, a second push should turn it off. If it's Message Waiting, you probably have to access voicemail.
Aug 20, 2014 | Nortel Lands Phones
Voicemail not picking up
Your unanswered calls go to voicemail if your phone is set to call-forward-busy-no-answer. If that got cancelled by mistake, then your phone will ring until they hang up or you answer. These phones work on a bunch of NEC systems, so I don't know what your cfbna code is. On the Pro II, the Elite, and the IPK, the code is 43 plus voicemail pilot number, if your codes are at default.
Jan 17, 2014 | NEC Lands Phones
My voicemail stopped working. The phone rings and rings but doesn't go to voicemail.
Press Speaker
Dial *6
Enter Voicemail # (will appear on screen if you hit your voicemail button)
Press Speaker again
Nov 27, 2012 | NEC Dterm DTP-2DT-1 Phone
NEC DT300 Series - Having a problem deleting a voicemail messages. I delete the message but the system isn't deleting the messages and the light won't go away. How do I do a hard delete?
Try accessing your voice mail from a different number. Just call your number and press pound once you hear ringing. If this doesn't work contact your phone company.
Mar 02, 2011 | Cell Phones
Voicemail Probelsm
I found the solution in some notes I have. Press Speaker, 43, 250, Speaker and the voicemail will activate. 250 being our central voicemailbox, you will need to know what your company's is.
Jul 07, 2008 | NEC DTU 8D-2 Corded Phone
Lands Phones Logo
568 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
