Question about Konica Minolta Office Equipment & Supplies
Code 61 how to fix error code 61 in Bizhub 363.
  • Konica Minolta Master
  • 3,646 Answers
Is it a network error code.
Could mean FTP TX interruption or SMTP connection rejection
check ftp settings are correct
http://www.manualslib.com/manual/421595/Konica-Minolta-Bizhub-223.html?page=63
Could mean smtp problem check settings
http://www.manualslib.com/manual/421595/Konica-Minolta-Bizhub-223.html?page=216
Posted on Apr 29, 2014
Konica 363 how to make password
Default password is 12345678 or 1234567812345678,Go to admin Setting punch in current password. then Security settings to change the password.
Sep 26, 2014 | Konica Minolta Bizhub 363 Copier / Printer...
I am having L code errors on our Konica Minolta Biz Hub 363
Sir/Mam,
#10 Transfer roller needs replacing sponge looking roller right side of the of the machine when you open to remove paper jams.
# 9 Developing unit needs replacement that the part that holds the drum and developer/toner. IF YOU YANK THIS UNIT OUT WITHOUT REMOVING THE LITTLE COVER ONE BOLT and DICONNECT THE CONNECTOR. BIG TROUBLE, going to cost a lot to repair.
#8 PAPER DUST REMOVER the device that collect paper dust yes paper does produce DUST. Just before the sponge roller
#6 IS Warning that the developer has not been replace inside the drum cartridge. SEE #9
#4 Drum need to be replaced.
Really have to watch for all of that sir/mam.
Apr 11, 2014 | Konica Minolta "Minolta Bizhub 363 Copier,...
Konica minolta 363 error message c2201
Toner bottle failure to turn. Shut off the machine remove the toner bottle, turn on the machine with the bottle inside it, wait for the machine go thru its paces when it ask for the toner install in correctly if the knub on the bottle is damage get a new one . if this does not work get a tech to look at it either the motor is bad or worse the control board is bad$$$
reset open close side door
Feb 24, 2012 | Minolta Office Equipment & Supplies
Konica minolta bizhub 363 error message c-2201
remove the toner bottle let machine thur its paces when it says install toner bottle install correctly
Konica minolta 363 error message c-2201
remove the toner bottle reinstall when machine ask for it.
Scan to email TX gives error code of 2 3/8 on a bizhub 363
Hi!
There is 3 things you can look at!!Make sure you have the correct gateway in the machine and that you have the correct smtp server address and that the email address is valid and working.
Hope it helps!!
Sep 20, 2011 | Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub 362: Any suggestions to the problem below? A very frustrating and error-prone device (in printer functionality). It's installed in a 20-user network who do use it lightly (total...
There is another solution but its more costly.All you have to do is to replace the parameter board of bizhub 362 with the board of 363 along with RAMs.
Mar 30, 2011 | Konica Minolta Bizhub 362 Copier
231 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
