Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
My freezer is not staying cold.
Ice melting and nothing is staying cold
    Sergeant:
    Champion:
  • 253 Answers
May you be having problem with compresser.and for more info contact http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
Freezer stays cold. Why is fridge part warm?
if freezer gets iced up the fan designed to pass cold air from the freezer to the fridge stops working. The freezer is meant to go into a defrost mode when its trtansducer senses too much ice. If the transducer goes fault the ice builds up. Some fridges use a timer to work this out so it could be a timer fault. Talk to a service man about how much ice the freezer should have for them to sucessfully diagnose the fault. Too much ice may prevent the service man from working out if temperature sensor is working and no ice can prevent him from testing sensor. To get rid of ice you have to trun off the power to the fridge and let it melt.
BEWARE remove food to another freezer and fridge to prevent food going off or getting food poisioning
Sep 17, 2015 | Estate TT14DKXKQ Top Freezer Refrigerator
Everstar HDIM 35 ice maker
Click below ;
There's no ice
Hope this may help
Jul 30, 2008 | Freezers
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
My GE Profile fridge freezer is having issues staying cold and also with preventing frost. Now it is melting from the ice bin.
If the auto defrost mechanism is not working, specifically, the defrost heater you will have ice buildup in unit and warmer temps all over. Check here for part(s) Search Over 2 1 Million Appliance Parts
Sep 07, 2017 | Refrigerators
I have a magic chef refrigerator that is not cooling. The freezer is working but nothing is staying cold in the frig. Could this be the thermostat?? Don't want to replace frig for a number of reasons. ...
next time send the model number,where is the freezer is it on top or bottom or side by side,anyway all the fridge does is get cold in the freezer and the evaporator fan blows cold air from the freezer into the fridge section and then it returns to the freezer just goes around until it gets cold enough and then the t-stat tells it to shut down so if the freezer is cold you either have a bad fan motor,open the freezer you should hear the fan blowng around in there if not the evap fan motor is bad,also touch the back inside wall of the freezer if there's any frost or ice on the back inside wall you have a defrost problem,bad timer or board,bad defrost thermostat or a bad defrost heater,the ice doesn't melt off of evap coil because one of the parts have failed,the air ducts get blocked with ice and the cold air can't blow into the fridge section,or if you see ice on the ceiling,side and back walls the door was left open and the air ducts blocked with ice,or one more thing if the freezer is on top and you have water dripping into the fridge section the drain in the freezer is blocked and the defrost water can't go down the drain hose,the water is freezing the air ducts up,the drain has to be cleared and all the ice has to be melted out,and yes there is one more thing it could be, some fridges have a damper in them,all it is is a door that opens and closes to let the cold air from the freezer blow into the fridge section so this is why you have to send the model number.but your problem is the cold air in the freezer isn't getting blown into the fridge section because the fan isn't working or the air ducts are blocked with ice.
Dec 31, 2017 | Refrigerators
It comes on a stay cold for about a week then it shuts down, what is the problem? Please help!
Check the defrost heater, sounds like it is burnt out allowing ice to build up therefore restricting cold air flow. Then the freezer warms up, ice melts and it starts freezing again.
Nov 30, 2010 | Delfield Freezer 6151XLSR Stainless steel
Icebuildupinsidebottomfreezerdoorwaterleakingoutofdoor
The freezer needs to be defrosted. Take everything out and put it in an icechest with some cold packs, and let the freezer sit open and off to allow the ice to thaw, use a pot or something to take the chunks of ice out and put in. Try not to get your floor too wet, but when too much ice builds up, the cooler cannot cool down the air, and the freezer is only staying cold because the ice is there, but the ice will melt since it has no way to stay cold enough to be below 32 degrees without the cooling unit to keep the temperature low.
Dec 13, 2009 | Frigidaire FRS20ZSG
The freezer is heating up at the botton in the back of the freezer it has heat and is red. The ice is melting and nothing is staying cold. Buts it only the freezer nothing else.
The red is the defrost heater , defrosting the evaporator coils . There is also a thermostat which cuts the heater off when it gets to 140 degrees (max) behind the freezer wall . The main control board will (should) terminate the defrost cycle in about 32 min. Only the frozen food keeps the freezer cold during this time .
Jul 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice on the bottom of freezer
Sounds like your freezer drain is blocked. first, turn the temperature controller up a little bit, maybe one or two stops, then wait 24 hours to see if the ice melts at all. If it starts to go away, then you may need to toss a few towels on the floor next to the freezer because 6 inches of ice melt is gonna make a mess.
After you get that sorted out, turn the temp down one click to make sure that everything is staying cold, and that the ice is not reforming.
good Luck!
Jan 25, 2009 | Frigidaire FRS23KF7AB Side by Side...
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
102 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
