Question about Vestax Music
Vestax 04FX power input damage
None of the repair people we've tracked down are willing to look at it as they all have deals with Pioneer etc... But basically, Vestax was knocked over by a cat, landed on the back side up. Took it to a gig and could only get it to stay powered on by taping the adapter wire down so it went in at a certain angle. After the gig not even this trick worked. Any thoughts appreciated. We already tried bringing it to a local electric store and tested the input with new adapters and have ruled out the adapter being the problem. Is there anything a soldering iron can do?
5 Suggested Answers
SOURCE: Loose AC connection to electronic piano
Your problem is most likely a broken cable in your ac cable. Try to replace the cord first (a place like Radio Shack will have replacements). If it's not the cable, then you might have a broken soldering point inside your keyboard. It might be too small of a crack to see, but redoing the soldering points should work.
Posted on Feb 06, 2009
  • 1138 Answers
SOURCE: No power cord or ac adapter
Sometimes the instrument or keyboard will have the power requirement embossed on the case near the receptacle for the power supply. Hope that helps.
Posted on Apr 23, 2009
  • 5603 Answers
SOURCE: CTK-541 does not work with power adapter connected.
You probably have a bad solder connection at the inductor which is a filter coil to reduce EMI.
It is not uncommon to have one of these heavier components bust the solder connection...
NOTE: It takes a trained eye to spot the little gray ring around the lead that says the connection is broken.
Reheat the solder of the connections on that inductor and see if that doesn't fix it. If not, continue tracing the voltage.
ALSO a cracked circuit board can manifest itself this way. USE A BRIGHT LED flashlight to "candle" the board and look for cracks.
Posted on Dec 25, 2009
Testimonial: "Bingo. By shining a light under the board, I saw that the + power pin layer had cracked, eliminating continuity. A short jumper did the trick. Thanks."
SOURCE: casio lk-33 does not work with external power
I once had this problem with another Casio synth.
I hadn't the power adapter ant I tried with an other one, with the same specifications : the synth was apparently powered but it didn't work.
I finally understood that it was a problem of polarity (+/-). You may just have to cut the cable and resold it inverted.
Hope it could help!
Posted on Apr 26, 2013
Have a marshall mg250dfx from usa so it is 110 v but i'm over seas and I use it with a step down transformer 220in-110out and it worked perfectly for some time but today wile i was playing it started...
Assuming the power in is good (I would check that first though, AC voltage going into the amp), then plug a patch cord(any 1/4" to 1/4") cord into the effects loop on the back of the amp and insert and remove a plug into the headphone jack a number of times to clean the contacts(headphone jacks and effects loop jacks are normally switching jacks that pass audio when not in use). Still not working?... If the pots(gain, volume and tone controls, etc.) are scratchy that could be the issue. The input jack could be the cause(damaged, cracked solder or circuit board trace). Wiggle the input jack to see if that causes or corrects the problem. A little WD-40 works wonders on correcting dirty jack issues. If none of the above are the cause then it is likely a cracked solder joint, trace or component lead which would have to be resoldered/repaired (maybe dirty contacts between the small effects board and the main board). Also watch the overdrive channel LED when the audio drops. If the LED goes off could be a power supply issue or a channel switching issue. Tapping on the amp will help indicate bad connections, cracked component leads or damaged traces.
Jul 03, 2013 | Music
My Zoom R16 wont turn on
Hi , i have the same problem, did you fix the problem already ?
Jan 06, 2013 | Samson Technology Zoom R16 Recorder /...
If I plug in powered monitors to the digital input... will it get rid of my error code 02 displayed on the screen ?
Never go from a PA (powered (amplified)) speaker signal to the inputs of a recording device. This can severely damage the electronics of the input/preamp. That error code may be getting caused by something else. For more details on how to use digital ins:
Apr 13, 2012 | Tascam 2488NEO 24 TRACK RECORDING...
Hello, I need assistance with my vestax pcv002 mixer. i need to replace the power cord since it has gone missing. Can i get just any generic DC15-A power adaptor or not? the proper vestax ones are much...
Provided the store which sells the universal type guarantees the voltage and current factor as available on the original Vestax, you can proceed to buy the type.
Also the product must be a good one to work without heating or have reduced life due to poor quality.
Mar 18, 2011 | Vestax Dc15a Power Supply
Hi, I have a DJM 400 Pioneer mixer, I'm having trouble with the output levels. It seems the left output is only putting out about half the sound of the right output.I have used different RCA cables,...
Please try a set of headphones. If it is balanced in the phones, then I suspect trouble might be in the muting circuits of the main output.
Next test is to verify the outputs using direct inputs to the CD input...
Dec 01, 2010 | Pioneer DJm 400 Professional DJ Mixer
Where can i send my vci 100 to get repaired ? neil mk
You don't give your location so start here: Try contacting the two distributors here: .
Aug 25, 2010 | Vestax Vci 100 Midi Controller
Need to change the fuse in a vestax pmc
Sorry, since the mixer is powered by a "wall wart" adapter, it is UNLIKELY there are fuses in the unit.
If it is inoperative, then check the voltage of your power adapter. If you by chance connected a wrong adapter, try the correct one. It is possible damage was done in this case that is not so easily fixed as changing a fuse. The correct adapter looks to be a type AC14 which LOOKS to be a 15 volt DC, 500 ma, with negative on the pin.
Jan 25, 2010 | Vestax Pmc 280 DJ Mixer
On the VCI-100, My left jog wheel is slow/sticky. is there any way to adjust it? It also causes the tracks to slow down or go backwards on it's own?
I suspect this uses an optical pickup. You need to open the unit and look at the sensor. If it is an optical pickup, then use the canned air pressure to clean the area of dust.
If it happens to be a mechanical switch, then the mechanical encoder has to be replaced.
Sep 09, 2009 | Vestax Vci 100 Midi Controller
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
Music Logo
35 people viewed this question
Top Vestax Music Experts
Michial Gueffroy
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Vestax Music Expert? Answer questions, earn points and help others
