Question about Yamaha RX-V871 - 7.1 Home Theater Receiver
RXV 871 not switching On
The amplifier was running perfectly well in the morning but when i tried to switch it on in the evening, it was not turning on, only the red led standby was glowing and nothing else is happening. its dead.
    Champion:
  • 216 Answers
Unplug for 10 minutes and try again. If not depress power button to get into set up mode and ck settings , if all else fails reset to factory defaults. P.S. "ck batteries in remote first"
Posted on Apr 21, 2014
Hi i have a tech magic 9kg working perfectly this morning the power switch will not turn on.
door switchs have a habit of failing . try laening against it when turning on .
Feb 15, 2016 | Washing Machines
My car started perfect this morning went into the store came out and complete loss of power wont turn over no light no radio completely dead
sounds like the battery may have gone or possibly even the alternator as it may not have been charging the battery - you need to have it checked out first
Apr 10, 2015 | 1998 Pontiac Sunfire
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
Peugeot 306 52 plate,pulled out the garrage one morning all perfect,left for 30mins tried to start to go to work turns over but wouldn't start,tried everything even diognostic machine of mine and the
Did you check for fuel pressure with a gauge on motor
or scan tool, if that data is avail?
Did you put one of those HEI Spark Plug testers in a plug wire
or cop coil
Do the cams turn
I'm not into the Peugeot, but is expect you may have a timing
belt ?
You may not have data on the ignition switch & its contacts
Do you have battery voltage to the ignition & injectors with key on
Injector pulse when cranking ( crank sensor !!)
Jul 26, 2013 | Cars & Trucks
YAMAHA RXV 350 Right Speaker not Working
The amplifier for this channel is NOT working.
Feb 09, 2012 | Yamaha RXV-350 Receiver
IF THE FAN TURNS ON WHEN HOT IT WON'T TURN OFF EVEN IF ALL SYSTEM IS OFF.
If the amp is off completley it sounds like the fan is running of the incoming 12Vdc line that is constant, not switched. That would be an issue with the amp manufacturer. There is a comparator circuit that uses a Thermistor that is RTVd to the power transistors heatsink block. When that voltage reaches it's reference voltage the fan will kick on. The amp manufacturer is switching the fan supply in with a relay to the 12Vdc line (more current capability) and the relay contact is stuck closed even when you turn the amp off. Does the fan run indefinitley or does it shut off over time?
Dec 13, 2009 | Earthquake Sound PH800W.2 Car Audio...
Strangely, my laptop (Sony VAIO with Vista Home Premium) doesn't display anything when turned on. But the green light is normal and no signs of blinking (it's perfectly normal!). I really don't know what...
Switch off the power supply & pull out the laptop battery then wait for 30 seconds. After that, install the battery back & switch on your laptop & enjoy.
Thanks for contacting Fixya.
Mar 25, 2009 | Smart Modular SV3170A
I am not very technically literate with respect to audio/video. I purchased a Cambridge Audio Azur 840a V2 Integrated Amplifier last week to replace an Arcam A70. I have a pair of Tannoy DC3 speakers, as...
get an Ohmmeter, take a reading on each speaker line one at a time, on both A & B speaker lines. You should get a reading of 8+/- ohms. The speaker switch with the 6 spks will probably read almost 0 ohms when all 6 are running. That is what your amp is not liking. Try running it with one set of speakers on the switch,with the Tannoys on ch A on your amp and the switch on B. add one pair of the 6 at a time and you'll see that it won't like all 6 at once. 2, maybe 4, at a time is probably what you'll find to work.
Good Luck.
Dec 18, 2008 | Cambridge Audio Azur 840A Amplifier
No sound
Make sure speakers are hooked to proper connectors. Also check speaker switch "A"/ "B"/ "A+B" is positioned to correct speakers.
Also make sure mute switch is off
Apr 27, 2008 | Yamaha DSPE390 Amplifier
Yamaha RX-V871 - 7.1 Home Theater Receiver Logo
103 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
