Question about JVC AM FM CD DET FACE CAR STEREO
Locked its stuck on check wiring and reset unit but it wont reset, how do i reset the unit to make it work again?
    Champion:
  • 216 Answers
Remove speaker wires and try to reset. If it resets ck wires for a short.
Posted on Apr 21, 2014
Maytag 5000 series washer control locked light is on and washer wont turn on
1. try unplugging or flipping circuit breaker, wait 10 secs, hold in power/on button for 5 secs, plug back in and see if it resets.
or
2. try tapping on door lock position on front of unit and see if it unlocks unit(lock stuck). hit it hard with palm, but not enough to dent or damage
good luck
Sep 24, 2016 | Maytag Washing Machines
(RCA OPAL M4204A) An update was sent via internet, it went to my unit and errased the data (as warned) and the OPAL's program. It will not leave the 'initialize' window. Turning on and off and on...
Push down the key lock switch, I think on your model it is on the side of the unit.
If it does not work, try performing the reset procedure below, From
ThaMp3Doctor
I quote
"Opal has a reset hole on the back of the unit in which atoothpick (non metallic) can be inserted to reboot the player. If thisdoes not work, I suggest that you reformat the player by using theWindows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device. "
If it still does not work, then the lock switch is probably faulty or stuck inside, in this case you need to take apart the unit, to fix it.
Try playing with the lock switch, or resetting the unit, that should unlocck your MP3.
Oct 27, 2008 | Audio Players & Recorders
IPad stuck on headphone mode
Try power down iPad and see if it reset to default setting if not go to setting icon and go through your setting options.
Sep 01, 2015 | Apple iPad 2 Wifi 16GB
Central locking button not functional and I can't lock the rear door glass
if its just 1 door that wont lock, I would say that the lock mechanism on that door has failed. When you press the central locking , you should hear each door "click" if its only 1 door, remove the door panel to check if any wiring has broken or dislodged. To check the door lock unit, I found it easier to remove it and check with a unit from one the doors that you know does work. If the good one you swapped over works, then that will mean that the lock unit has failed, if the good one doesn't work on that door, then you know it will be a wiring or connection fault to that door.
Apr 13, 2015 | 2001 Hyundai Santa Fe
I have a brand new whirlpool wfw70hebw Duet washer that is stuck in the "draining" mode- the door is locked and the lock light is flashing red and it sounds like the drain pump is running. None of the...
I think you have a coin or something stuck in the drain pump itself. I have had to remove the pump,and take out the coin, reinstall it and it works perfect.
Jun 18, 2014 | Washing Machines
KDC-MP4032 head unit wont turn on
hi, seeing that your kenwood showed up "protect" you may have an audio circuit/amplifier fault within the unit. try resetting the unit to see if unit comes "on" again. if the unit comes on and protect flashes again, then you definitely have an internal audio circuit fault. if not then check all power connections(yellow and red wire voltages, as well as ground connection), as well as the condition of the face pins!
May 31, 2012 | Kenwood KDC-MP4032 CD Player
2006 toyota tacoma trd automatic wont start
join www.tacomaworld.com and go there to ask this question
Apr 19, 2017 | 2005 Toyota Tacoma
Ge front load wcvh6600.
our door kept sayin "door locked". a technician came out to see it and said it was the door lock but that he had temporarily fixed the problem. he said to call if it happened again and would have to order new door lock which runs about $160. after six washes it said door locked again. he came out agian and within 5 minutes of diagnosis said it need a new door lock. i was furious bc i had already payed him and found an new door lock on Ebay for about $70. Got the manual off the internet and had my hubby replace door lock. not very hard except when he replaced it it still said dook locked. after several hours i told him to unscrew the bottom panel because i had seen tec do the same. to our amazement, one of the wires had come loose and needed to be plugged back in. amazingly it started working perfectly. then , i put a big load of towels in and it started shaking badly again and the same problem reoccured. DOOR LOCKED. so we took the bottom panel off and the wire had com loose again. we stuck it back in and wah-la... it worked again. this has happened about 4 times now and everytime we just open them bottome panel and replace wire. i believe we never even needed the new door lock to begin with? we havent checked putting the old door lock back in but i bet it would work because it looked like nothing was wrong with it when we took it out. I hope this helps before you spend an extra $200 or so like we did for a loose wire. we have now just left the front bottom panel off and when it happens, i just bend down and tighten. Hope this helps.
Apr 26, 2008 | GE WCVH6260F Front Load Washer
No sound
Hi guys
It sounds like the unit has locked up from a power flip type situation. I suggest powering the unit down completely overnight and then fire it up again in the morning and see how it behaves. Some of your system menu presets may have lost their settings and may need to be setup again also. Get back to me here if you have the same condition after doing a full reset in this manner.
regards
Graeme
Dec 25, 2007 | Onkyo TX-SR601 Receiver
Help front panel wont work and treble +10 keeps coming up by itself
Check all of the push buttons on the front panel.. I have seen that sometimes a switch could have gotten jammed or pushed an and broken and the button gets stuck and wont let anything else work
Sep 21, 2006 | Yamaha HTR-5650 Receiver
JVC AM FM CD DET FACE CAR STEREO Logo
197 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
