Question about Irons
How can I get my Domena SP400 steam press to produce steam
The pump is working, the steam iron heats up OK but does not produce steam. Can I fix this myself?
    Champion:
  • 216 Answers
Blockage " mineral deposits" get a de-scalar and follow the directions. Only use distilled water in steam iron.
Sometimes vinegar will work depending on mineral deposits causing blockage.
Posted on Apr 21, 2014
  • 320 Answers
SOURCE: steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Posted on Mar 26, 2009
SOURCE: Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Posted on Jun 25, 2009
brnspncr
  • 67 Answers
SOURCE: MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Posted on Aug 04, 2009
  • 3 Answers
SOURCE: domena excellence sp400 how to change thermostat
You can get a manual from http://safemanuals.com/brand-user-guide-instructions-owner-manual/DOMENA, unfortunately they charge for there manuals. I believe if you where in the UK asking this question you will get an answer faster from a local dealer! Good Luck!
Posted on Nov 29, 2010
SOURCE: MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Posted on Sep 08, 2012
I have a domena steam press and there is water coming out and soaking the clothes. Water comes out as steam but as well as this it drops out as water.
Lime scale build up inside the elementchambers causing poor heat transfer to the water the steam being cooler thAn usual condenses back into water it reaches the porthole the steam is ejected from and you get this leaking effect steam and water together your need to professionally get the device descaled
Jul 03, 2016 | Irons
My domena steam press leaves brown stains on my
You may have to use only distilled water in your iron.
Sep 14, 2014 | Irons
Hi my swan steam gen iron is faulty , when I press the steam button it pours with water from the metal plate part of the iron , any ideas ??? Thanks
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle .
Feb 27, 2013 | Irons
My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
Nov 14, 2012 | Irons
Feb 29, 2012 | Irons
For my singer electronic steam press esp2 can i use deironise water instead of distilled as i can not get any distilled water in any of the shops in my area.
You can try the deionized water but you may have trouble with it producing enough steam...water that is too pure may not produce steam well depending on the way it is heated.
If it does not produce enough steam just add a bit of salt to the water and it will work well.
heatman101
Aug 13, 2011 | Singer Electronic Steam Press
I have a Bosch Steam Generator Sensixx B25L that has suddenly stopped producing steam. The iron gets hot so that bit is ok, help, I have a huge pile of ironing!
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Jun 01, 2011 | Irons
Domena excellence sp400 how to change thermostat in steam press need to take a pin out to get access to elements and thermostat
Nov 28, 2010 | Singer Irons
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
Steam gauge is broken and iron will not produce steam
  • Screwdrivers
  • Sewing needle
  • Steel wool
  • Emery cloth
  • Metal cooking pot
Mar 26, 2009 | Rowenta Irons
Irons Logo
267 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
