Question about GOLD STAR LLC MV1611ST 1.6 cu. ft. 1000 Watts Over The Range Microwave Stainless Steel FACTORY REFURBISHED FOR USA
Fan will not stop - GOLD STAR LLC MV1611ST 1.6 cu. ft. 1000 Watts Over The Range Microwave Stainless Steel FACTORY REFURBISHED FOR USA
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
Fan is normally controlled by a microswitch which can be accessed by removing top cover, you may have to replace the microswitch but this should only be carried out by a licenced electrician as high voltage is involved
Posted on Apr 24, 2014
Fan stays on, microwave does work, how can I get the fan to stop running?
Hello, Wanda -
Until you can have your microwave repaired, if that is what you ultimately wish to do, you can pull out the plug from the electrical outlet for the power cord for the microwave.
With no electric power, the fan will stop.
Jan 10, 2018 | Microwave Ovens
Can it be used without the fan?
If you want to get anymore useful life out of it, stop operating it without the fan.
Aug 18, 2015 | Whirlpool Microwave Ovens
Fan failure /Intermittent heating
quite likely your microwave is trying to prevent it self from self destruct, because if the fan is not keeping the electronics components cool enough while its running the high limit thermo will disconnect power from the heating circuit, if the fan is not working it should be replaced , that's a techs job.
Feb 12, 2014 | Microwave Ovens
Work light and fan stopped working
sounds as if your touch pad ,and,or the circut boaed it's connected to is going bad.
Nov 08, 2013 | Kenmore Microwave Ovens
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
Samsung SMH7178STD microwave fan stopped working
It looks like the part of your computer board on microwave which responsible for controlling light and fan stop working. In this case you have to replace computer board.
Dec 03, 2008 | Samsung SMH7178STD Microwave Oven
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
GOLD STAR LLC MV1611ST 1.6 cu. ft. 1000 Watts Over The Range Microwave Stainless Steel FACTORY REFURBISHED FOR USA Logo
Top GOLD STAR LLC Microwave Ovens Experts
William Miller
William Miller
Are you a GOLD STAR LLC Microwave Oven Expert? Answer questions, earn points and help others
