CD/DVD Drive Tray problems There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work. Go to My Computer and right click on the drive and click on Eject. If this does not work then you can manually open the CD/DVD drive tray by - Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc. If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
It won't play for one of two reasons: 1. There is something inside the DVD player, which keeps it from playing. 2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc. Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens. If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
What you need to do is to prepare philip screw and oil. 1.) open the back cover of your dvd by unscrewing it. 2.) look for the center area specially on the door. 3.) put an oil where the door close and open. You can also put oil to all moving parts for much better result. 4.) then try to test it if it works, hope it helps you and rate me if it does.thank you..
